Previous in Forum: resistance related   Next in Forum: Use of Dimmer switch as Fan regulator
8 comments
earth resistance value
11/08/2009 3:20 AM
What should be earth resistance value as per IE rule 1956 or 2003. Is it within 10 ohm? Is resistance value depend on type of load or substation?
Location: N.E. Alberta 55.6329 N Lat. 111.0729 W Long. Canada
Re: earth resistance value
11/08/2009 8:32 AM
The answer is yes!
Could be worse, it could be me. :)
11/08/2009 9:32 AM
Can you provide relevant IE rule?
01/07/2010 11:26 PM
it should be less than 1 ohm
02/14/2011 11:11 AM
We required minimum & mximumvalue of earth resistance
Thanks,
Mali Jagannath
04/25/2023 7:18 AM
The minimum value of anything is either zero or minus infinity.
11/08/2009 12:16 PM
i think it should be less than 4 ohm
11/09/2009 12:41 AM
For earthing requirements please refer to IS 3043 for installations in India.
Atlas Shrugged - JGD
Good Answers: 170
11/13/2009 4:50 AM
No standard on the globe, mandates a certain maximum permissible value for system earth resistance. Definitely NOT in any of the 143 IE Rules. Wherever the IE Rules mention about the value of earth resistance, it just vaguely says that the earth resistance should be "low enough". But, how much is low enogh? SO is tha case with IS 3043. It also says only "low enough". Even IEEE does not specify a certain maximum permissible earth resitance.
However, there is clause in the Indian National Electric Code, 1985, which says that for equipment earthing the earth resistance should not be more than 5 Ohms.
Anonymous Poster (3); Current Maarey (1); electricalexpert65 (1); ion mihaiu (1); mayt2u (1); PWSlack (1)
