Previous in Forum: failure   Next in Forum: genset
12 comments
Transformer Impedance
11/09/2009 12:07 AM
Hi All
I have a transformer 1200KVA 690/433V 5.09% impedance. I can calculate the short circuit impedance with these values. My question is can this be considered the overall impedance of the transformer. I am getting two values using two different methods. one is 0.0137 ohms and the other is 0.0073 ohms. Can some one please tally it up. I understand this a very basic calcs, but I need this value right so that I can calculate the total earth fault loop impedance and calculate the touch voltages.
Re: Transformer Impedance
11/09/2009 12:11 AM
Answer to your question is NO.
How did you get the other values?
11/09/2009 4:22 AM
Thanks mate
I will take you through the cals
----> sqr(V)/S = (sqr(433)/1200000) * 5.09/100 = 0.00795 ohms
----> 5.09/100 * 433 = 22V. FLA is 1600Amps
Therefore 22V/1600A = 0.01375
The second calculation is for the short circuit impedance and the first one is using the base values. Which one is correct??
Thanks again..
11/09/2009 11:07 PM
hi guest,
can you explain the same method for 500KVA, 11/415V, 5%?
11/09/2009 9:29 PM
Use this example
Given:
Connection: D-Y (4160V/480V) Size = 300KVA Ipri = 79.92A Isec = 692.62A
PF = Cosq = 0.25 Sinq = Sin(Cos-1q) = 0.968
R = 1.7% = 0.017pu @ 300KVA base X = 4.96% = .0496pu @ 300KVA base
Using primary side:
Zact = Zpu x Zbase I = 79.92A Zbase= V2/Sbase = (4160)2 / 300KVA = 57.685W
Ract = (.017)( 57.685) = 0.98065W
Xact = (0.0496)(57.685) = 2.86119W
VD = IRCosq + IXSinq ÿFrom IEEE Red Book
VD = I[RCosq + XSinq]
VD = 79.92[(0.98065)( 0.25) + (2.86119)( 0.968)] = 240.85V
VD3q= VD x ÿ3 = 240.85V x ÿ3 = 417.16V
VD3q % = (417.16V / 4160V) x 100 = 10.03%
Belgium - Member - New Member
Good Answers: 21
11/10/2009 5:16 AM
Is this correct or am I wrong ???
P = I x U x sqrt (3)
300 kVA = I x 4160 x 1.73 so Ipri becomes 41.7 Ampères ....
300 kVA = I x 480 x 1.73 so Isec becomes 361 Ampères ....
11/10/2009 12:43 PM
You are right.....even I doubted my calculating abilities...remaining part of reply by Wareagle also I couldn't get.
"Know something about everything and everything about something"
Good Answers: 21
11/12/2009 7:08 AM
Nor did I understand the remaining part. .......
Perhaps Wareagle can explain it one more time ....
Or the one who rated this as a good answer ...
11/10/2009 10:42 AM
you can consider it as overall impedance of the transformer .
before starting calculation , you have to assume base MVA, V, I, Impedance.
in your case
transformer impedance = 0.0509 * (base MVA / 1.2 MVA )
Good Answers: 59
11/10/2009 2:02 PM
I can't quite make out what you are saying.
Could it be that the lower impedance is the series loss impedance (effectively the series resistance) and the higher one is the impedance at short circuit?
If so, the reason they are different is that the true short-circuit impedance must include the transformer's leakage inductance, whereas the loss impedance relates to the losses when the transformer is loaded with a largely resistive load - and the main effect of the leakage inductance is to change the phase of the output rather than the Voltage.
Good Answers: 59
11/12/2009 7:59 AM
I looked up the standard definition of winding impedance: it is the effective series impedance (= leakage-inductance plus transformed winding resistances) of the transformer.
% winding impedance is the winding impedance as a percentage of the impedance needed to generate nominal loading.
There will be two values for this - one viewed from the supply side, the other viewed from the load. Which you want depends on the application.
Having said this, the numbers in the header-posting are both wrong. I wouldn't care to disinter how you got there, but the correct formula is:
Zwinding = Vnom2/VArating x (%impedance/100)
So the winding impedance viewed from the 690-Volt side is specified to be 0.02-Ohms, and the impedance viewed from the 433-Volt side is specified to be 0.008 Ohms.
(BTW, the full-load currents should be 1739 and 2771 Amp rms respectively, and it all comes out in the wash)
11/16/2009 6:38 PM
Sample Voltage Drop Calculation Across Transformer
XF2-001:
Given:
Using primary side:
VD = IRCosq + IXSinq From IEEE Red Book
VD3q= VD x √3 = 240.85V x √3 = 417.16V
Using secondary side:
Zact = Zpu x Zbase I = 692.62A Zbase= V2/Sbase = (480)2 / 300KVA = 0.768W
Ract = (.017)( 0.768) = 0.013056W
Xact = (0.0496)( 0.768) = 0.0380928W
VD = I[RCosq + XSinq] = 692.62[(0.013056)( 0.25) + (0.0380928)( 0.968)] = 27.80 V
VD3q= VD x ÿ3 = 27.80 x ÿ3 = 48.15 V
VD3q % = (48.15V / 480V) X 100 = 10.03%
11/16/2009 6:49 PM
This is a correction to the first post
XF2-001:
Given:
Using primary side:
VD3q= VD x √3 = 27.80 x √3 = 48.15 V
aliN (1); Anonymous Poster (2); giri (1); Physicist? (2); rudy.leurs (2); wareagle (4)
