Previous in Forum: DP. and PT. Definitions   Next in Forum: Thread Gauge for Unplated Male Threading
What is Back Purging?
11/09/2009 3:16 AM
Back Purging and Oxidation of Root Pass
what is back purging anyway?
I am not a home work cheater. I am a translator seeking professional help
Re: Definition of "back purging"?
11/09/2009 4:46 AM
Is it in context ot TIG welding? pipes? when you do it, then the Argon (usually, but may be some other inert gas too) is not only fed through the TIG nozzle, but also fed to the inside of the pipe so (with the ends closed) so that the molten metal (of the weld) is not exposed to air and hence liable for oxidation. It is in the inert gas atmosphere like the top layer (facing the nozzle). This is a common practice for the pipeline TIG welding.
Good Answers: 94
11/10/2009 4:35 AM
We also use argon backing gas for fine welds in high vacuum equipment.
Re: What is Back Purging?
11/10/2009 9:25 AM
As already mentioned, typically Argon is used. The gas that comes from the TIG torch is your shield gas. The gas that you run into the inside of the pipe is the purge gas if you don't get a full purge you'll get what they call "sugaring" which is oxidation and it looks like black sand typically this happens on stainless.
11/10/2009 1:41 PM
One must be very careful not to completely close of the ends of the pipe. A tiny hole should be available (1/16" or so) to allow the gas to escape. Without the hole, the last little bit of the root pass will "suck back". Also only a very low flow (5-10 cfh) should be used so that the external shielding gas is not blown away. A low pressure flow meter should always be used.
11/11/2009 10:24 AM
Do you want to know about Back Purging ? Ok just go through
Freelancer.com .There are thousand of providers are waiting for you. They are ready to do anything for you. Just visit and use a unique code "
NUTSANDBOLTS" to get some extra features. Just remember the code.
Thanks
Anonymous Poster (1); heba66 (1); Nigh (1); pipeit (1); Profemeritus (1)
