Previous in Forum: Simple overwind protection for Constant Force Spring   Next in Forum: What is Back Purging?
DP. and PT. Definitions
11/08/2009 8:18 PM
Φ10.2 drill 32 DP. to PT.
M12*1.75 TAP, 22.2DP.
4 holes spaced as shown
what does DP. and PT. mean respectively? Sorry i can not insert the drawing .
I am not a home work cheater. I am a translator seeking professional help
Re: DP. and PT. definition
11/08/2009 9:16 PM
I can get you halfway there. "DP" means "deep." Apparently 10.2 mm drill is the correct size for tapping M12x1.75 metric threads. But I haven't learned or figured out "PT" yet. (It might mean "partially threaded", since you are not threading to the bottom of the hole.)
Good Answers: 114
11/08/2009 11:02 PM
I'll take a guess that PT is point as in drill point.
11/09/2009 3:17 AM
tks dude ,PT stands for point in this context
11/13/2009 5:15 AM
Hmm... I saw your problems and
I think you need some professional help to develop your Mechanical Engineering. If you need it, just visit Freelancer.com . You will find there thousands of great Mechanical Engineers who are really very helpful. You will get some extra facilities if you use this unique ' NUTSANDBOLTS' coupon word .
Have a very nice time
bye
Re: DP. and PT. Definitions
11/10/2009 9:58 AM
This is a metric way of dimensioning a hole. We in the U.S. measure a hole to the rounded end of the drill not to the end point of the drill.
In this case, the engineer wants to drill and tap 4 holes.
He wants to use a 10.2 mm dia drill and an (M12) 1.75 dia tap drill.
The 4 holes are 10.2mm (Dia) X 32mm deep to the end point of the drill and
tap the 4 holes to (M12) 1.75 X 22.2mm deep.
heba66 (1); hernaju1 (1); passingtongreen (1); Tornado (1); wingman1985 (1)
You might be interested in: Guides Bushings and Drill Bushings, Drill Bits, Taps
