Hi All,
I just ran across this site in searching for an answer to a problem that I am trying to solve, and wondered if you all could assist in determining an answer.
I have an application where I have a 4" dia. PVC riser that floats in an accumulator which my pump draws from. The exterior of riser is at atmospheric pressure, when the system operational with constant circulation, the float forces the riser up to it's operational height.
The riser will stick partway up due to excessive friction caused by the seal, I have not been able to find a seal that works and I would like to eliminate it. Is it possible to eliminate the seal & have small enough clearance for water to provide the seal?
It is not possible to use a seal on the float (when it is forced up all the way against the enclosure to provide sealing), as the riser's height is dynamic & is dependent on the water level of a larger body of water (swimming pool).
I hope that I have been able to accurately convey my problem.
Thank You & Best Regards To All,
Jon T
