Previous in Forum: Technical/Design specification for ASME VIII pressure vessels.   Next in Forum: Pickling & Passivation
Stainless steel & carbon steel welding electrode
11/11/2009 3:55 AM
Dear All
I have small tank stainless steel, I should weld angle leg carbon steel, so I need welding electrode to weld the angle on the tank.
Regards
Re: Stainless steel & carbon steel welding electrode
11/11/2009 4:15 AM
E 309
11/11/2009 4:20 AM
1.- <What kind of SS is the tank?
2- Weld a pad (Same SS material) to the tank (ie. E309-L)
3.- Weld the angle leg (CS) to the pad (ie E309-L)
11/11/2009 4:46 AM
Dear Guest
SS material SA 240 316L (pad for the leg same material of tank)
CS angle leg Q235 or equivelant
Actually we use E309 for SS, but Iam not sure can we use it in our case.
Regards
11/11/2009 7:58 AM
11/11/2009 5:52 PM
It's better to use a numerically higher filler rod/wire than the base metal.
In your case, since I know nothing about the environment, I'd say 316L filler is fine.
Abusaleem (1); Anonymous Poster (3); lyn (1)
