Previous in Forum: Stainless steel & carbon steel welding electrode   Next in Forum: Surface treatment
Pickling & Passivation
11/13/2009 1:34 PM
What is the pickling & passivation for the stainless steel?
Re: Pickling & Passivation
11/13/2009 11:29 PM
Good Answers: 243
11/14/2009 10:41 AM
11/14/2009 4:22 PM
Thanks Mr Milo
Good Answers: 243
11/14/2009 7:26 PM
You're welcome.
I was trying to find a copy of the article my colleague wrote, but it seems to be hiding. This was relevant. Welcome to CR4!
milo
11/20/2009 12:09 PM
Pickling is a process by which a material is treated in a combination of chemicals, usually acid solutions, to remove oil, grease, dirt, muck, rust etc and is not necessarily specific to SS. However, the solution used would be something specific to SS e.g., a 10% soln of HCl + HF. Whereas passivation of SS means developing the corrosion resistant layer of Chromium Oxide (Cr2 O3) on the surface of an SS material by treating with Nitric Acid solution. The excess acid should be washed off.
11/20/2009 1:44 PM
So acid pickling removes oil and grease?
11/24/2009 6:35 AM
have a look at this doc, there is an introduction that explain the difference between descaling, pickling, passivation and cleaning:
http://www.euro-inox.org/pdf/map/Passivating_Pickling_EN.pdf
and also these other docs are useful
http://www.google.com/cse?cx=010231287511253103195%3aqmfpcvv02be&cof=FORID%3a1&q=pickling+passivation+stainless+steel
S
corrosion prevention & control
Register to Reply 7 comments
Abusaleem (1); Anonymous Poster (2); bm (1); Milo (2); strider6 (1)
