Previous in Forum: INVETER HEAT PUMP (WATER)   Next in Forum: Municipal Well Water Destroying plumbing fixtures
downhole drilling
11/14/2009 2:55 AM
why do some downhole drilling tools need to be hammer or shot peened
Re: downhole drilling
11/14/2009 4:21 AM
Good Answers: 243
11/14/2009 10:20 AM
To answer your specific question, Shotpeening of stainless and high alloy steels reduces galling. Shot peening also improves fatigue strength by putting outer surface in compression. In my opinion, It also helps to minimize corrosion by "homogenizing" the surface finish, eliminating major differences (pits and highspots) that could set up galvanic cells.
In my experience, there are three ways that peening can improve performance: cold work effects, Surface effects, and compressive stress of surface effects.
here are a couple of references for your study:
http://www.shotpeener.com/library/pdf/1990026.pdf
http://www.shotpeener.com/learning/spo.pdf
This company is probably the best resource in this area:
http://www.metalimprovement.com/
Also check out this company that several of my clients have used:
http://www.arrowcryogenics.com/shotblasting.htm
milo
You might be interested in: Earth Drilling and Boring Services, Peening Shot
