hello everybody, this is sunil doing final yr mech engg....v r doing our proj in motor handling equipment....i want to know how to calc the press req to lift 300kg motor to an height of 2m........first the motor is in ground level v will fix the motor in the fixture then v will rotate to 180 deg then v will lift it to an 2m ht to fix it in pan mixer assembly in batching plants........its very urgent 4 me.......the rough design will be avail in http://www.orkut.com/Album.aspx?xid=16225908253520169414
