Previous in Forum: CALCULATION OF PRESSURE   Next in Forum: Press Required to Lift 300kg Motor
Scissor Lift Force Question
01/09/2007 9:46 AM
How to arrive at force needed to lift scissor lift by pneumatic cylinders? The total load on the scissor lift is 300 kg.
Re: Scissor Lift Force Question
01/10/2007 9:43 AM
This is a simple problem in trigonometry. The maximum force needed is when the scissors jack is closed or at its collapsed position. At the extended position a minimum is required.
Not knowing the geometry and dimensions of the collapsed jack, a WAG is on the order of 3 to 5 times the load.
Depending on what you are lifting a hydraulic cylinder might be a better choice of motive power.
Reply to Forum Thread
You might be interested in: Lift Tables, Hydraulic Cylinders, Air Cylinders
