Previous in Forum: Alternative Material for Blade of Industrial Fan   Next in Forum: is it possible for a reciprocating pump to have back flow to suction side
What Does "In Bending" Mean?
11/17/2009 2:40 AM
The 20° pressure angle is broader at the base and hence stronger in bending.
does "in bending"mean "when subjected to bending" ? Sorry for my ignorance on this subject.
I am not a home work cheater. I am a translator seeking professional help
Re: what does "in bending"mean?
11/17/2009 3:19 AM
This looks as though it pertains to gear/rack teeth. If you push the whole tooth axially, it will try to slide along the root, which is a shearing action. (The force is "in shear.") If you push the tooth at the top, it will try to lean over, or bend. (The force is "in bending," and it involves leverage rather than sliding alone.) This is a rather basic verbal summary, but I hope it helps.
11/17/2009 7:36 AM
I'm curious what it is you do. Your questions at first led me to believe that you were a student. Now I believe that you are in industry in a position that is new to you.
Which is it, student or newbie?
11/17/2009 9:08 PM
I'm also curious as to what you do. The speed and number of your posts at first lead me to believe that you are retired. Now I believe that you are maybe out of work.
Which is it, out of work or retired?
How could answers like this possibly be of assistance to the OP?
Register to Reply Off Topic (Score 8)
11/19/2009 8:57 AM
I've wondered about that myself. Score 2 for GQ
Re: What Does "In Bending" Mean?
11/18/2009 4:23 AM
Bending materials means that you press them into another shape. Every material will resist this manipulation; every material will also react differently.
So if you bent a material, say to a 90° angle and you then remove it out of the bending equipment it will stretch back to e.g. an opening angle of 92°. If this is within tolerance it is OK, but if you need the 90° angle as an end result you will have to make an "in bend" (angle smaller than 90°) to obtain 90° angle as end result.
How much this "in bend" effect has to be is depending on the material (stainless steel, Aluminium, alloy) and the thickness. The best result you get when you test the combination of material and bending equipment, pressure during bending process, time of bending
Good Answers: 94
11/18/2009 5:15 AM
The question was just about the terminology, in this context the answer is yes 'in bending' means when subjected to bending.
11/18/2009 7:11 AM
Finally, a sane and simple answer...
Register to Reply 7 comments
Anonymous Poster (3); lyn (1); Nigh (1); Rien Dutchman (1); Tornado (1)
