Previous in Forum: Gasoline Fuel Tank Design for Three-Wheeler   Next in Forum: Matching the Clutch Capacity with Demanded Torque
Carburetor Overflow
11/18/2009 2:00 AM
What are all the other causes for carburettor to overflow through breather pipes.
Tell causes other than the stuck float needle.
The carburetoor is positioned in an environment where the temperature is around 75 to 80 deg C
Re: Carburettor over flow
11/18/2009 6:32 AM
I would say the float itself. Those made from plastic may develop cracks, letting the fuel come into them. In this case the needle doesn't get stuck, but the buoyancy is totally or partially lost.
Good Answers: 266
11/18/2009 7:24 AM
Float miss adjusted. Seal fuel reservoir.
Good Answers: 15
11/18/2009 7:25 AM
read the homework restrictions for this site please
If you don't have time to do it right the first time, when are you going to have time to do it over?
Register to Reply 3 comments
charlie_r (1); fernandotasso (1); ozzb (1)
