Previous in Forum: DP LEVEL TRANSMITTER INSTALLATION FOR CRYGONIC APPLICATION   Next in Forum: Flow Sensors and Flow Measurement
Shielded Cable vs. Braided Cable
11/18/2009 3:44 AM
What is the difference between Shielded cable & Braided cable? What is their application area?
Re: Shielded cable & Braided cable
11/18/2009 8:04 AM
Braided cable is multiple strands of smaller wire sometimes braided together to form a larger conductor. It is more flexible than solid conductor cable and will survive more bend cycles.
Shielded cable has an outer metallic (usually braided) sheath that can be used to isolate the cable from interference or prevent the cable from producing interference in other circuits or devices.
Wiki probably gives a clearer answer, check there. Some examples below:
India - Member - Naveen Menon Engineering Fields - Instrumentation Engineering - Naveen Menon
Re: Shielded Cable vs. Braided Cable
11/19/2009 12:14 AM
Links attached , hope it heps clear your doubt..
http://en.wikipedia.org/wiki/Shielded_cable
imagesReport the following images as offensive. Confirm CancelThank you for the feedback.
Register to Reply 2 comments
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
