Previous in Forum: All Purpose Mechanic   Next in Forum: sl500 w129 No fuel flow
Mercury Water Chiller Refrigerant Charge
01/10/2007 5:27 AM
Good Morning Folks
Some one out there must have the answer to this. We have a Mercury Water Chiller
Type MC3500A
Serial No 7891
Having contacted the manufacturer and waited two + weeks for a response I challenge the readers to assist.
What is the refrigerant charge per circuit???
Life is terminal, No One Gets Out Alive, It is therefore better to travel than arrive
Re: Mercury Water Chiller Refrigerant Charge
01/10/2007 8:36 PM
Do we assume "Mercury" is a brand name?
Chills water? How much? Compressor? What type, centrifugal?
If I had one with the same type I might know what refrigerant it uses. Otherwise ? ? ? ?
If you let a little refrigerant escape the system does it flash to gas or can a little liquid be withdrawn?
WAG Freon 113?IIRC
01/11/2007 4:52 PM
Did you try the sales rep?
Is this a drinking fountain?
Call the mfg. on the "ding a ling." Tug on their chain!
Register to Reply 2 comments
