Previous in Forum: IC Datasheets   Next in Forum: Is My Hard Drive Failing?
Encryption Board PCI-Express
11/19/2009 7:11 PM
I am searching for encryption board PCI-Express that supports RSA 2048, AES, triple DES and SHA 256.
Vendor, technical document anything will be OK!!!
Thanks!
Pathfinder Tags: AES RSA 2048 SHA 256 triple DES
Re: Search PCI-Express board supporting RSA 2048, AES, triple DES and SHA 256
11/19/2009 11:47 PM
CPU's today are perfectly able to handle encryption without co-processor boards, e.ghttp://www.jetico.com/encryption-bestcrypt/
Charlie don't surf.
11/21/2009 7:04 AM
Depends what your after, I too am looking for encryption offload cards, so far only found HiFN (http://www.hifn.com/) with 1.8GB/s encryption capacity in their 'Express DR 1625' and many other lower end devices either built with FPGAs (http://www.indranetworks.com/) which get about 0.13GB/s and a few based on packet/network processing ICs from Cavium Networks and Broadcom.
Good Answers: 68
Re: Encryption Board PCI-Express
11/22/2009 10:31 PM
Hi meetatop,
You may find what you want below.
  • [PDF] PESB62- Security Protocol Processor PCI Express Server AdapterFile Format: PDF/Adobe Acrobat - Quick View
    for 3DES, DES, AES and ARCFOUR symmetric encryption algorithms, for the SHA-1 and MD5 ... RSA Public and private key operations up to 2048 RSA bit modulus. • 1024-bit DSA sign and verify ... Support for PCI Hot Plug functionality as supported by your ... PCI Express Base Specification Revision 1.0. Board Size ...
    www.silicom-usa.com/downloads/pdf/PESB62.pdf - Similar -
  • PESB62 - Security Protocol Processor PCI Express Server AdapterThe Silicom protocol processor server adapter is a complete PCI Express server adapter solution ... DES, AES and ARCFOUR symmetric encryption algorithms, for the SHA-1 and MD5 hash ... RSA Public and private key operations up to 2048 RSA bit modulus ... Failover support for Broadcom SSL Accelerator adapter devices. ...
    www.silicom-usa.com/default.asp?contentID=680 - Cached - Similar -
    Show more results from www.silicom-usa.com
  • [PDF] SafeXcel 171-PCI CardFile Format: PDF/Adobe Acrobat - Quick View
    supports a comprehensive set of algorithms, including: • DES, Triple-DES, and AES encryption. • MD-5 and SHA-1 Hashing with HMAC. • Public Key computations: ... comprehensive cryptographic library with each board. This ... Generate IKE Phase 1 Context (skeyid_a, d, e, etc.) • Compute IKE Phase 2 Context ...
    www2.safenet-inc.com/Library/3/SafeXcel-171PCI_Card_ProductBrief.pdf -
  • [PPT] PowerPoint Presentation Template_Gradient Blue_March 2004File Format: Microsoft Powerpoint - View as HTML
    9372 DES3 keys; 2568 RSA 1024 bit key pair; 1840 RSA 2048 bit key pair. ExtToken library supports secure external storage of token objects for: RSA signing; Checking certificates; DES key exchange; DES encryption transaction; ... AES, Triple-DES, DSA, RSA, ECDSA, HMAC-SHA-1, HMAC-SHA-256, HMAC-SHA384, HMAC-SHA-512 ...
    indico.rnp.br/getFile.py/access?contribId=10&resId=0...slides...13 -
  • Validated 140-1 and 140-2 Cryptographic Modules#265); AES (Cert. #163); SHS (Cert. #246); HMAC-SHA-1, HMAC-SHA-256, HMAC-SHA-384, ...... The SmartCard platform has on board Triple DES and RSA algorithms and can ..... "The RTL-TDEA Crypto Module is a PCI card developed to encrypt and ...... It supports on-card Triple DES, AES and 2048-bit RSA algorithms with ...
    csrc.nist.gov/cryptval/140-1/1401val2004.htm - Cached - Similar -
  • Multicore » Sun Microsystems, Inc. » The UltraSPARC® T2 Processor9 Oct 2008 ... In addition, the SoC includes an on-chip PCI Express (PCIe) controller and two native 1 Gigabit ... Full duplex encryption/decryption; Supports bulk encryption, ... DES/3DES, AES (128-, 192-, and 256-bit key lengths), AES-GCM ... support for RSA, DSA, and Diffie-Hellman operations for up to 2048 bit ...
    eecatalog.com/multicore/2008/.../the-ultrasparc-t2-processor/ - Cached - Similar -
  • [PDF] Express DS 4050File Format: PDF/Adobe Acrobat - Quick View
    DES/3DES in CBC Mode. Authentication: • SHA (256, 384). • AES-GMAC (128, 256). • AES-XCBC-MAC-96. • HMAC-SHA-1 ... ECDH-256, 384, 521. • ECDSA-256, 384, 521. • RSA, DH (1024, 2048, 4096) ... The DS 4050 offers support for Suite B encryption and ... Optional PCI Express GMAC using Intel 82576 Dual port. PCIe 2.0 ...
    public.hifn.com/Hifn%20Document%20Library/HifnPB-4050.pdf -
Good luck
Register to Reply 3 comments
Anonymous Poster (1); babybear (1); stevem (1)
