Previous in Forum: GibbsCAM Basic Information   Next in Forum: Eng. Fares Hadad
how can i know the dc motor torque
11/20/2009 4:30 AM
how can i know the dc motor torque?
Re: how can i know the dc motor torque
11/20/2009 5:12 AM
Try the manufacturer's data sheet
11/20/2009 5:16 AM
It's easy enough to measure it's torque at zero rpm (stall torque?) by mounting a bar to the output shaft and hanging weights on it, then slowly applying power.
The relative safety of this depends on the size of the motor (I deal in small 12v/24v Dc motors which draw about 1/2 and amp stall current)
Good Answers: 101
11/20/2009 10:23 AM
i can know the dc motor torque by measuring it with a torque meter .
Good Answers: 18
11/20/2009 3:48 PM
Power is torque times angular velocity, therefore, if the nameplate gives motor horsepower, the torque (at peak HP) should be HP/angular velocity. There's a scale factor involved for a given unit of angular velocity, so look it up on the internet.
Register to Reply 4 comments
Bill (1); DVader1000 (1); JohnDG (1); user-deleted-1105 (1)
