Previous in Forum: WPS helping tips   Next in Forum: Visual Examination of Longitudinal welds in pipelines.
WORMGEAR SELECTION FACTORS
11/22/2009 2:56 AM
Sir:
Please explain the significance of Efficiency, Derating, Services Factor , Correction Factor etc. with specific reference to the selection of Double Reduction Wormgear.
Many Vendors are telling me that all the terms are same and there is no need to consider all the factors. According to them efficiency includes everything.
If somebody can guide me the significance of the above terminology with the sample calculations , I shall be obliged.
Pl guide.
T J SHAH
Re: WORMGEAR SELECTION FACTORS
11/22/2009 5:02 AM
Except efficiency, the other factors are almost similar.
eg service factor
The basic terminolgies with a bit of explanation
Here is the procedure (but does not talk about efficiency)
11/22/2009 5:14 AM
Thank you very much.
Can you please guide about efficiency of the wormgear?
How efficiency and the links given by you are different?
Pl guide.
T J Shah
11/22/2009 5:27 AM
Sir:
Efficiencies claimed by different manufacturers are different mentioned in range. If everybody is manufacturing as per the same code, why efficiencies are different? Which are the governing factors influencing the efficiency of the wormgear? Due to self-locking feature of the wormgear will there be any derating over a period of time ?
T J Shah
11/22/2009 11:14 PM
Also the self locking feature is a part of the worm technology and is the advantage provided by it (ie driven can not drive the driver)
Depending on your size and quantity requirement did you look at the options ?
single stage bevel+ planetary chain typically will have efficiency above 95% along with compactness.
11/22/2009 11:11 PM
The efficiency is a bit different from other factors.
As you know the worms do not (and can not) rotate in the pure rolling contact - like the involute gears do. The sliding contact reduces the efficiency of the system.
Different profiles are created by different manufactureres with claims of improved efficiency.
AGMA is silent on the profile aspect, rather liberal.
As per AGMA 6022-C93
"The thread profile or shape of the thread flanks ... no limitation is placed on the method used except that the hob or the tooling used to produce the worm gear should have substantially the same profile as the worm so that..."
AGMA 6034-B92 gives the worm efficiency calculations. However that may be out of your syllabus .
http://www.roymech.co.uk/Useful_Tables/Drive/Gear_Efficiency.html
These typically gives the efficiency about 50 to 95% or so. And you may have the suppliers claiming.
However in our gear boxes, a bit large, with ratios about 15:1 to 25:1 we have rarely achieved above 80-90%
