Previous in Forum: Heating a MS Ingots   Next in Forum: WORMGEAR SELECTION FACTORS
WPS helping tips
11/21/2009 3:16 AM
Dear All,
We are preapring a WPS for plugging purpose of U-bendle heat exchnager type DXU due to some leakage in tubes during hydrotest. please find details as under:
Tube: A 210 Gr A-1 (OD x t 20mmx3.5)
TubeSheet: A 285 GrC (Thick 280mm)
Plug (Tapered): A 322 Gr1335
Tube side pressure & Temp. : 255kg/cm2g @ 117Degree Celcius
now problem is that as per UCS-56 PWHT is not mandatory if fillet weld with throat thickness does not exceed 13mm, tube OD 2inch and Carbon Content 0.22% respectively.
Q: However, In our case only problem is that only carbon content is exceeding from 0.22% while other requisite are qualifying all requirements as per UCS-56 (c) (2). Is PWHT is required or not?
your urgent resposne to the above is highly appreciated.
Nothing is permanent except change!
Re: WPS helping tips
11/21/2009 3:27 AM
It is mandetory, because there is no way to reduce carbon percentage.
11/21/2009 8:41 AM
Many thanks for your prompt reply....
Good Answers: 18
11/22/2009 12:45 PM
Is your Carbon content of 0.22 % is as per the manufacturer's certificate or actual checked by spectra analysis. If it is as per the certificate, pl. analyze it again, as any reduction in the figures will help U to avoid PWHT.
Sridhar.
What we have done for ourselves alone dies with us: while what we have done for other and the society remains and is immortal.
11/21/2009 8:48 AM
is there any reference (TEMA, API) to make plug w.r.t tube I.D. leaving manufacturing practices?
Register to Reply 4 comments
milindaur (1); NG (2); SRIDHAR (1)
