Method for machining right toothed bevel gears, wherein: at least a part of the tooth flanks is milled with a disc milling cutter, the left tooth flanks are milled at a different time than the right tooth flanks, the machined bevel gear is rotated by an angle between the milling process of at least one left tooth flank and the milling process of at least one right tooth flank, the inclination of the axis of the disc milling cutter remains unchanged during the milling process of said gear, said angle being not a multiple of the base pitch alpha.
