wat is servo fault..
i m using a plasma cutting machine, vulcan 1000, lock former maker.
the fault is x servo fault...i interchanged the cards of x n y axis..but the error message does not reverse..
so it is confirm that there is no .problem with the servo card...
wat is the criteria to check the card and servo motor..
earlier we had replaced the card in same scenerio to start the machine..but this time i dont think that there is a card problem...i saw the card by opening its cover..there is no blackening or deposition of carbon over the pcb..
