Previous in Forum: Hopper Design   Next in Forum: Axial Piston Pump or Vane Pump?
Pressure Tapping and Rod Removal
11/24/2009 6:58 AM
Dear All,
I ask this question after i did so many experiment.
In 20 mm pressure taping i inserted a 18 mm rod to give clearence for the refractory lining inside the blast furnace. After completion of refractory i tried to remove it, as refractory material is totally dried i am unable to get the rod out.
As this pressure taping is very important I used all mechanism and failed to do at last.
Please give better solution. Thanks
Re: Remove the 18mm rod from the pressure taping
11/24/2009 7:32 AM
Chill it by several tens of degrees centigrade. The thing will go loose in its hole and can then be driven out with a blunt instrument.
11/25/2009 6:16 AM
Thank you very much
Register to Reply 2 comments
