hi, i currently have a problem with a 3ph motor that shows a earth fault, firstly can someone explain why it matters what direction i put my test leads onto the motor? i.e if the red lead is on u1 and black on earth, i get an 1.3Mohm earth fault but if i connect the leads the other way round i have no fault?? why is this? also what would cause an earth fault? is it likely to be moisture ingress? can you fix the fault or do i need a new motor?
appretiate your advice.
Bill
