Previous in Forum: change of job   Next in Forum: Calculating Engine Power Outputs
Negative & Zero sequence currents
11/26/2009 1:46 AM
He friends,
I will be very thankful, if someone explain about the negative sequence currents and zero sequence currents
anand.mandarapu
India - Member - New Member
Good Answers: 164
Re: Negative & Zero sequence currents
11/26/2009 10:35 PM
11/27/2009 2:40 AM
I don't understand this, but, this is the Symmetrical components page from Wikipedia.
11/27/2009 8:55 AM
It is not too difficult to understand .
Any unbalanced three phase system (or for that matter balanced too) will have the three phase (say voltage) - of un-equal magnitude (or say amplitude) and they will not be equually spaced in time (ie the phasors will not be 1200 shifted rather it will be shifted by some other angle)
Right?
Now we do not like that behavious, we like things to be symmetric, that helps us in our calculation.
So what we do is we try to convert this three phase system into a set of other three phase systems such that their superposition gives us the current system
The zero sequence part is the one that is common to all the three.
The positive sequence is similar ie the three phases at 0o, 1200 and 240o (called sequence ABC)
The negative sequence is opposite to it ie at 0o, 2400 and 120o (call it sequence ACB)
Now obviously
Voltage of phase A = the sum of three at zero ie V0+V1+V2
But for B we have to rotate these ie = V0(common to all) + V1 (Rotated back by 120 deg ie rotated forward by 240 deg) +V2 (rotated forward by 120 deg)
and for C it is = V0 + V1 (rotated forward by 120) and V2 (back by 120)
That is what is in the matrix.
rest is the inverse to find the values of the sequences.
Good Answers: 164
11/27/2009 8:59 AM
A clever schoolteacher got around your signature statement - the worm wasn't earlier than the bird, he was coming in late, drunk after an all-night party
Register to Reply 4 comments
Anonymous Poster (1); kvsridhar (2); Randall (1)
