Previous in Forum: calculation of efficiency of brown stock washers and its other designing formula   Next in Forum: how to calculate the holding force
8 comments
adhessive
11/26/2009 12:49 PM
can we join to metals with an adhesive n wht kind of an adhesive can be use ..their name ..n up to wht thickness of metal can we join ...
what v do is what v are..mechanical engineers
Re: adhessive
11/26/2009 1:05 PM
Epoxy adhesives are pretty good, but it's all about joint design, surface preparation and choice of adhesive.
Re: adhessive
11/26/2009 1:07 PM
thnkx ..wer do i get tht is it avilable in india
Re: adhessive
11/26/2009 2:03 PM
If you have to ask, then you may not be qualified.
Re: adhessive
11/27/2009 5:09 AM
Just hopefully this engineer is not making a bridge glued with epoxy.
Well the bridge too may be a small one (like the languages), the consonant conjoiners (vowels) deleted so no problem except some children may cry.
Never thought- just struck- the vowels are like fasteners- keeping the main body - consonants- together.
Re: adhessive
11/26/2009 2:11 PM
Google, 'epoxy adhesive' 'structural adhesive' 'adhesive joint design' etc there are loads of epoxy adhesives, manufacturers websites should give info.
It also depends on the application. If all else fails ...experiment.
I'm in UK, you are in India presumably?...and you are asking me where it's available in India...how on earth would I know?
Re: adhessive
11/26/2009 10:43 PM
If you can not be arsed to at least try to write in English why should I bother to answer. Keep this sort of writing, if you must, to when messaging with your equally lazy young mates.
Steps of soapbox...............................
Re: adhessive
11/26/2009 2:01 PM
It also depends on how durable and what kind of load one anticipates on the joint. To adhere a sheet of paper to a metal surface, simple adhesive tape will do. To attach a metal label to a metal chassis many metal labels come with a solvent triggered contact adhesive already on the label. There's also the myriad of cyanoacrylate products (Crazy Glue, Eastman 910) that work quite well depending on the load.
Re: adhessive
11/27/2009 8:13 AM
Epoxy adhesives, cyanoacrylate adhesives and impact adhesives can all be used in the right circumstances.
Most mechanical engineers will favour a more predictable fastening such as bolts, rivets or welding.
Register to Reply 8 comments
Anonymous Poster (2); PWSlack (1); rajeshpassi (1); redfred (2); user-deleted-1105 (2)
