Previous in Forum: how to calculate the holding force   Next in Forum: Mechanical Linkage
Quench Press force in pounds
11/26/2009 4:17 PM
Hi All
Need assistance here.
a hydraulic quench press which can apply 1000-40000Lbs load on a center ram (Called an expander) the center ram has a tapered mandrel attached that has 30 Deg taper.
There is an segmented shoes that locate the ID of an ring gear. the Internal dia is tapered to match the tapered mandrel above.
the ring gear has to be expanded .010 total
The ring gear will be heated to 1500 Deg F
the material of the ring gear is 9310 steel with a yield stress of 155000. PSI
the estimated flow stress is 10% of the Ys
what is formula used to calculate the load in pounds (LBS)
Thanks in Advance
Good Answers: 68
Re: Quench Press force in pounds
11/28/2009 11:32 AM
Hi Guest,
You have given several force measures.
Can you say in just a couple of sentences what you are pressing, and do you need to know the exact 'press' force in PSI over the complete bed?
Or do you want to know how much the ring gear can, or has to expand before breaking?
11/28/2009 12:54 PM
what is the force to expand the ring gear to round it up not break it, I have been racking my brain.
the flow stress = yield stress x 10%
dimensions of the ring gear is 13.169 ID, 15.730 OD
x 3.260 width.
Thanks for your help.
Good Answers: 68
11/28/2009 2:38 PM
Hi Guest,
You will have to 'rack your brain' a little more as I need more detail, not least of which is exactly what you want to know?
What do you want to convert or know in Lbs? And is that psi?
What measurements are you using. You give sizes but no details of mm, or Inches?
Please?
11/28/2009 3:14 PM
sorry babybear
The dimensions of the ring is in inches (Imperial)
The force I need to calculate is in PSI
The closest formula I can find is the book Sheet metal Forming Process & Die Design
Link below
http://books.google.com/books?id=e-WMObwib4EC&pg=PA92&lpg=PA92&dq=expanding+sheet+metal&source=bl&ots=HqDk4t4nUe&sig=0lTQmgnfVFIijHO9Yn1bFd1BbfA&hl=en&ei=JWsRS7mbCsGInQfjuIjaAw&sa=X&oi=book_result&ct=result&resnum=6&ved=0CCcQ6AEwBTgK#v=onepage&q=expanding%20sheet%20metal&f=false
11/28/2009 3:39 PM
sorry link does not go directly to the page I was previewing
Go to preview the book, then go to page 92 expanding rings
once again thanks
Good Answers: 68
11/29/2009 1:04 AM
Hi Guest,
I thank you for your last but one and your last post.
Problem is there was only some pages I could open and 92 was not one of them.
If you can search or tell me what to search for and we may find your info, OK?
