Previous in Forum: Overlap Seam Welder Machine Controller   Next in Forum: Electrotechnical system for 1000 kW WES
Cable Drum
01/12/2007 12:56 AM
I want to know in detail the required torque for reeling and unreeling of cable of 100kg weight, 4 core,10 sqmm,30 mm overall outer diameter.
Re: Cable Drum
01/12/2007 11:05 PM
Are you "Winding us up?"
You will have to give US the details!
What size drum?
How much cable?
How fast?
What kind of cable?
What type? Electrical? Hoist?
Etc. Etc.
Re: Cable Drum
01/17/2007 2:33 AM
Drum Size:
Dia of cable drum (min.) = 500 mm
Width of cable drum = 600 mm
Cable details:
Length = 150 mtrs.
4 core, EPR cable,10 sqmm
Overall Dia of Cable = 30 mm
Minimum Bending radius = 8 D
cable has to reel and unreel within 5 minutes
i.e. cable drum speed = 16 rpm
Electrical cable
United States - Member - Engineering Consultant Popular Science - Evolution - Understanding
Re: Cable Drum
01/13/2007 12:04 AM
Hmmmmm
Sounds like a snare drum to me.
Its in detail, (or rather just underneath it) of de horse.
Your lack of specifics has ME reeling.
Re: Cable Drum
01/13/2007 4:44 AM
Is this part of someones homework question?? sans detail.
Re: Cable Drum
01/13/2007 1:43 PM
it's all depend on your bearing friction brother. What kind of bearing you used to support the drum. search for rolling friction. normally 10% of total weight(cable + drum) for roller bearing is enough. but you need to cater the inertia for the drum when stopping/brake also. get what i mean.
Re: Cable Drum
01/15/2007 8:38 AM
Is the product copper, steel or alluminum? If steel, what is the carbon content? What is the empty diameter of the spool? Is this take-up following a strander or is it taking up from another spool? Is the payoff static or dynamic? Is the tension controlled by a dancer? What is the amount of tension you will be trying to maintain for your package?
Register to Reply 6 comments
garth (1); Greg G (1); oldelectrician (1); poonam (1); Stirling Stan (1); zichau (1)
