Previous in Forum: 2004 dodge pickup horn issue   Next in Forum: Code Reader for 1996 Kia Sportage
9 comments
Automatic Mondeo won't gain speed in 1st, jumps in reverse, clinking noises
11/28/2009 7:29 PM
My 1997 Automatic Ford Mondeo started fine this morning, but when I put it in reverse it wouldn't move then jumped back a few times. In first gear it didn't start to move until it was at 2-3000 revs, then pretty much rolled around the corner at 15-20 km/h max. It really felt like it was struggling and was making clinking noises when I pressed the accelerator gently so I pulled over immediately.
I noticed it was picking up really slowly yesterday, not moving in 1st till the revs were up at 2-3000, but it was fine once it changed gears. Then this morning it never got up enough speed to change gears. I know absolutely nothing about cars but I'm assuming there's a problem with the gearbox/transmission?
Any ideas on what the problem might be? Is it safe to drive to a mechanic or should I get someone to come to me? If it is the gearbox/transmission what is a round about cost for repairs/replacement?
Thanks so much for any ideas/help!!!
Pathfinder Tags: Automatic slow pick up
Re: Automatic Mondeo won't gain speed in 1st, jumps in reverse, clinking noises
11/28/2009 11:16 PM
From what you have described, the transmission is worn out. The causes could be a weak pump, which has allowed the transmission line pressure to be too low, which has burned up the clutch packs. No matter what the cause, the transmission needs to be rebuilt, or replaced with a new unit. I would not drive the vehicle. Tow trucks are way too resonable to fool around with trying to drive something like this.
Test first, replace parts later
11/28/2009 11:47 PM
Thanks so much, great to at least know what's going on :-). Very much appreciated!
11/29/2009 10:42 AM
Sounds like an oil problem to me. Either low oil or poor pump pressure. If it's very short of oil you could wreck it in short order. I wouldn't drive it untill it's fixed.
Richard Harris
11/29/2009 7:13 PM
Much appreciated, I'll check the oil, and the atf was low when I looked at it (idling in park), but still the correct red colour. I'll see how it goes after topping the fluid and oil up. Then at least I'll know if it's more serious. Thanks so much!! :-)
Good Answers: 68
11/30/2009 1:14 AM
Hi mondeodriver8,
The oil may lessen the 'clinking sound' but that clinking sound is very ominous! Sound as bwrench said, that you are in for a rebuild , and replacement of the clutch and gearbox.
Modern gearboxes are so reliable it often comes as a shock when they do fail. It is one of the few things on a car that you cannot get you hands dirty up to your elbows trying to look into it while it is still on the engine?
I would check out the clutch for sure, and the gearbox must be removed to do this so it is the perfect time to get in rebuilt or replaced with a renovated one?
Just in passing, does anyone know of a clutch for a car or truck where you do not have to remove the gearbox to have it replaced?
Happy holidays to all
11/30/2009 1:25 AM
Yes. Some of the early model Saab cars could have the clutch replaced without engine or transmission removal, and also the Datsun B200 could have the clutch assemble replaced without removing the engine.
Good Answers: 68
11/30/2009 1:33 AM
Hi bwrench,
WOW! I asked on the off chance and did not expect to get a positive reply like yes!
I wonder why this system was not picked up and used on other vehicles? It is such a pain having to replace a clutch, and while doing so it is relatively easy to screw the shaft of the gearbox as I replace it! That is apart from the weight of the gearbox making the job even more a PITA!
I will search those vehicles out and see the difference.
Thank you so much! And happy holiday!
Good Answers: 94
11/30/2009 4:54 AM
The original Mini had a transverse engine with the gearbox in the 'sump'. The clutch was housed in the end of the engine & could be changed by jacking the engine up on that side. Perhaps this is the same for other transverse engines.
11/30/2009 4:37 AM
First port of call should be your "filter", the AFT system should have a filter between oil storage and clutch, any blockage at this filter will not allow the sytem to engage the clutch correctly( i think it is an oil pressure system) I once had the same problem when I needed a run-up to get up a hill. Seemed a big worry but such an easy fix.
Hope this gives you other options
Register to Reply 9 comments
Anonymous Poster (1); babybear (2); bwrench (2); mondeodriver8 (2); Nigh (1); telzar (1)
