Previous in Forum: Standard Fuse Ratings   Next in Forum: Connecting Three-Phase ELCBs
Multiplying Factors and Monthly Electric Bills
11/30/2009 1:30 AM
I wanted to know as to whether we got to use the multiplying factors to calculate the total unit consumption if a CT meter is used. This is in case of a monthly electric bill?
Re: MULTIPLYING FACTOR
11/30/2009 2:32 AM
Hi guest,
All digital meters are shown direct readings, hence there is no need multiply with the multiplying factor.
If the meter is anologue, the reaings are need to multiply with the multiplying factors. Hope you got the point
11/30/2009 5:31 AM
if you have CT ratio then y can muti ply this with reading
Good Answers: 170
11/30/2009 6:13 AM
The multiplying factor is normally specified by the meter manufacturer and is usually displayed on the meter name plate. However, the multiplying factor may or may not be a direct reduction of the CT ratio. Sometimes, it also includes a certain number of rotations of the disc (in case of electromechanical type meters) per kWh.
Good Answers: 244
11/30/2009 8:13 PM
Please the previous thread http://cr4.globalspec.com/thread/45679
It will help.
- MS
anand.mandarapu (1); electricalexpert65 (1); msamad (1); tmp_patel (1)
