The aim is to make available an compact machine that can produce ice at the shortest possible time in a tropical enviroment.
The principle I intend to employ is a simple vapor compression system
and using brine as a secondary refrigerant. The high temperature and
high- pressure
refrigerant (primary refrigerant) leaving the compressor is condensed
and collected in a receiver, it passes through an expansion device and
through evaporator coils surrounding the brine tank. This low pressure
refrigerant will absorb heat
from the brine solution and when it gets to the vapour state it is once
again fed into the compressor forming a simple vapour compression
cycle. Water in modified ice cans is placed in tanks surrounded with
cooled brine, the brine which acts as a secondary refrigerant will be
kept at a constant temperature of -10oC by action of a thermostat
connected to the compressor and it will also be moved in constant
motion by an agitator to improve heat transfer between water in the ice
cans and the brine solution. The brine then absorbs heat from the water
in the cans.
This is the point I am at now, what else do you think I am lacking?
Thanks a lot for your help.
Cheers.
