Previous in Forum: 1998 Ford Contour - Master Cylinder   Next in Forum: Repair Manual for VW Passat
Brown's gas in Diesels
11/30/2009 9:55 PM
We are selling and installing a Brown's gas generator on large diesel trucks. Our unit works fantastic on Detroit 60 series with No O2 sensor as well as Cat twin Turbo pre 2005 no O2 sensor up to 30% however on Cummins ISX and Volvo we get zero results. Does anyone out there know why the Cummins and Volvo do not get better mileage from injecting hydrogen and oxygen when the other two get great results. I think it is in the ECM or the EGR system but do not have any details on the various systems. We know why it will not work on engines with O2 sensors therefore we will not install since we know there will be no gain. Since we are adding clean fuel there should be consistent results all things equal. Thanks In Advance.
This discussion was "closed" on 11/30/2009 10:55 PM. No new comments are allowed.
Message from admins:
HHO, Brown's gas and similar posts that do not provide supporting data from reputable testing agencies will be closed/deleted.
Re: Brown's gas in Diesels
11/30/2009 10:30 PM
Before this thread is (likely) shut down, please look at the numerous previous threads on CR4 regarding Brown's gas and its use with anything remotely resembling an internal combustion engine. I believe the O2 sensor question was also answered.
11/30/2009 10:32 PM
Just out of idle curiosity, what is the address of your state's Consumer Protection Division?
Register to Reply 2 comments
