Please i need information on pipeline offtakes. What are the major issues a design engineer should consider when installing offtake points on a pipeline?
Thanks
It is the mark of an educated mind to be able to entertain a thought without accepting it.... Aristotle
You are new to this site and I suspect that you are also new to the "Piping" world. If not true then please accept my apologies.
First, some terminology.
"Offtakes" is not a proper piping term. I think you mean "Branch Connection" as in connecting a NPS 10" (DN250) branch to a NPS 20" (DN500) header or main line.
The major issues include:
The maximum operating pressure
The maximum operating temperature
The commodity
The wall thickness of the header
New construction vs. new branch to existing header
Tie-In status (Cold Tie-In or Hot-Tap Tier-In)
The available options (unreinforced stub-in. reinforced stub-in, TEE, Weld-O-Let, split Tee)
