Previous in Forum: What are Soft Goods?   Next in Forum: Carbon to Iron ratio
Leakage in Austempering Furnace
12/03/2009 12:16 AM
Dear,
We are using Austempering furnace, conveyor Belt type, Electrically heated, to Heatreat the Spring Steel parts. Furnace temperature is maintained at 870 °C ± 5 °C. The furnaces sometimes shows leakge during working and also when we restart the furnace after maintenance. we put Palster of peris to fill the leakage area but it is not effective and leakage start again and again.
can any one suggest the Material and process of applying it which we can use as a leak proof so the leakage can be eliminated.
Re: Leakage in Austempering Furnace
12/03/2009 2:03 AM
You may use high temperature resistant ceramic blankets to fix the leak. These have to be clipped to the wall or joints using heat-resistant pins which are hooked or welded to the metal lining (outer steel shell) of the furnace by making a small hole through the insulation layers.
12/04/2009 2:13 AM
I have used this company's products before. They may have what you need.
Sauereisen, Inc. - Company Profile | Supplier InformationThis is not a commercial endorsement.
12/05/2009 10:12 AM
I completely agree with muralidar. Seal the holes with high temp furnace cement and back them up with reinforced high temp steel.
12/13/2009 1:43 AM
any chemical / solution that can be applied from outside on the joints?
Register to Reply 4 comments
CS Muralidhar (1); lyn (1); sailer_666 (1); samp (1)
You might be interested in: Heating Furnaces, Industrial Furnaces, Vacuum Furnaces
