Previous in Forum: 25 Years Ago - Bhopal Tragedy: Worst of Chemical Engineering   Next in Forum: Leakage in Austempering Furnace
What are Soft Goods?
12/02/2009 7:59 PM
Medical oxygen distribution systems shall be according to metals criteria as described by this standard. Conversely, soft goods selection criteria are outside the scope of this document. Soft goods in the flow stream require special consideration that is based on the system operating pressure and toxic by-products of soft goods in a combustion event.
what does soft goods mean here?thanks.
I am not a home work cheater. I am a translator seeking professional help
Re: soft goods
12/03/2009 7:27 AM
Anything readily combustible - elastomers? Plastics?
Re: What are Soft Goods?
12/07/2009 10:52 AM
Good old Wiki:
In economics, a durable good or a hard good is a good which does not quickly wear out, or more specifically, it yields services or utility over time rather than being completely used up when used once. Most goods are therefore durable goods to a certain degree. These are goods that can last for a relatively long time, such as refrigerators, cars, and DVD players.[1] Perfectly durable goods never wear out. An example of a durable good might be a brick. As a counter-example, sticky tape is not very durable.
Examples of consumer durable goods include cars, appliances, business equipment, electronic equipment, home furnishings and fixtures, houseware and accessories, photographic equipment, recreational goods, sporting goods, toys and games.
Durable goods are typically characterized by long interpurchase times--the time between two successive purchases.
Nondurable goods or soft goods (consumables) are the opposite of durable goods. They may be defined either as goods that are used up when used once, or that have a lifespan of less than 3 years.
Examples of nondurable goods include FMCGs such as cosmetics and cleaning products, food, fuel, office supplies, packaging and containers, paper and paper products, personal products, rubber, plastics, textiles, clothing and footwear.
Durable goods, nondurable goods and services together constitute the consumption of an economy.
Register to Reply 2 comments
