Previous in Forum: BMW Crankshaft - Specifications and Drawings   Next in Forum: How Do Bike Manufacturers Calculate Mileage?
Engine Brake
12/03/2009 8:52 PM
We have design addional Break which fitted with Engine which control the vehicle by air pressure and breaking speed serially i. e. 10 -9 -8 -7-------0 not 10 to 0. This break should be working as desire by owner, if not desire, it will be easilly connect / disconnect. it will be connected directly with engine. This break working by air presure no drumd / dish reuired.
My aim is findout the new technology for energy where no fuel, required. ,
Re: Additional Break
12/04/2009 1:32 AM
What's the point? Modern vehicle brakes are fine. You are adding expense and complexity for no reason.
12/04/2009 11:19 AM
Google "Jake brake"....
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
Re: Engine Brake
12/05/2009 12:47 AM
Old concept. Been in use for decades in heavy duty trucks/lorries.
If you are looking to replace the conventional disc/drum brake system with this concept, there is a potential for major liability when a failure occurs.
Conventional braking systems are well proven and reliable technologies. Anything out of the norm of standard practice will have the lawyers circling.
Speak softly and carry a big stick.
Re: Engine Brake
01/04/2010 7:30 PM
Compression braking is outlawed or restricted in some locales due to damage (from heavy vehicle such as log haulers ... such as in Washington state, USA) that such braking causes to roads.
Then there's the noise, which in some localities could be frowned upon.
... a case of "Why re-invent the wheel?"
Re: Engine Brake
02/09/2010 7:15 AM
How does compression braking damage a road?
Re: Engine Brake
02/09/2010 10:47 PM
The Brake and Road is direct relation with road and road must be effected. But it ia applicable to all Brakes not for particular this Brake. And what ever I immage this Brake is without noise. This is additional Brake and useful to serially braking speed, which not good where traffic.
Register to Reply 6 comments
Anonymous Poster (2); B. R. PATEL (1); Calnet42 (1); lyn (1); standarded (1)
