Previous in Forum: Current Transformer (CT) Protection   Next in Forum: Torque Motor
Circuity Breakers
12/06/2009 1:45 AM
What is the differance between MCB and MCCB
Re: Circuity Breakers
12/06/2009 5:27 AM
http://www.google.co.in/search?hl=en&q=MCB+MCCB+DIFFERENCE&meta=&aq=f&oq=
Results 1 - 10 of about 16,100 for MCB MCCB DIFFERENCE. (0.44 seconds)
Especially look here
http://www.plctalk.net/qanda/showthread.php?t=16445
Explained in detail.
Good Answers: 170
12/06/2009 10:06 AM
I have explained this in an earlier posting too.
MCB is Miniature Circuit Breaker, available with continuous current ratings from as low as 0.5A to as high as 125A, and with breaking capacities of a maximum of 10kA.
Whereas an MCCB is a Moulded Case Circuit Breaker, avaialble with continuous current ratings from as low as 16A to as high as 3200A, and with breaking capacities from 10kA to 75kA.
So, the difference is in their breaking capacities. MCCBs can break a much higher current than an MCB.
12/07/2009 12:34 AM
Dear electricalexpert65
If a circuit is rated for 50 A & max. short circuit current is expected to be 7 kA, then which should be selected, leaving aside commercial reasons since MCCB is costlier than MCB. No other accessory is required in the breaker ( e.g. aux. contact or shunt trip coil etc. etc. )
Thanks and regards
Ashok Toshniwal, Bangalore, India
12/07/2009 3:20 AM
Is the circuit to be protected single phase or three phase? Bear in mind that the fault current can be double on a three phase circuit when tested with a single phase tester.
12/07/2009 4:25 AM
3 ph.
Anonymous Poster (1); ashoktoshniwal (2); DSM2512 (1); electricalexpert65 (1)
