Previous in Forum: commissioning of LT heater   Next in Forum: Circuity Breakers
Current Transformer (CT) Protection
12/06/2009 1:10 AM
In the TPS class CT, the factor 'Rb'( Rated Resistive burden ), what it means and what is the deciding factor for 'Rb' value .
In performance wise, a CT with lesser 'Rb' is preferred or the higher one is preferred.
Can anyone explain the above pls.
Good Answers: 170
Re: Current Transformer (CT) Protection
12/06/2009 10:10 AM
The resistive burden is the Resistance Component of the total impedance connected to the CT Secondary side. The deciding factor would be the Knee Point Voltage of the TPS Class CT.
Higher the Rb than the design rating, the saturation will be quicker and vice versa. The actual resistive burden connected to the CT Secondary will decide the actual saturation of the CT and hence the protective system performance.
12/06/2009 5:40 PM
Thank-you very much for your reply.
As you may know, as per IEC 60044-6, Eal=Kssc*Ktd*(Rct+Rb)*Isc, in which, as a purchaser,I specify the Eal,Rct,Isc and Kssc(=Issc/CT ratio) in my CT specification.
So, the CT supplier has the option to to supply the CT complying IEC with higher 'Rb' & lesser 'Ktd' or with the lesser 'Rb' & higher 'Ktd', as the remaining factors are fixed in the above equation.
In the above context, which CT I can prefer in terms of performance, or is there any guidlines in the IEC for the minimum value of Rb or Ktd.
Thanks.
