Hi,
I work at a factory that some fans are used here.
there are some problems that I explain:
1- the position where fans installed are very wet and humidity is about 60 %. after 5 years shafts of fans are necked in places that are incontact with bearings.
2- so when we wanted to change the shafts, we havd to destroy the pulley of fans. because the shaft was stick to the pulley and we couldn,t seperate shaft and pully with press.
what is the reason of this problem?
If humidity is the reason or not?
why the shaft in places that are incontact with bearings are necked?
how we could prevent of these problems ?
how we could change the shafts?
Thank you.
