Previous in Forum: Crystalline Buildup in Pump and Pipework   Next in Forum: Vertical Drilling Machines vs. Lathes
S-Pitot Tube for Measuring Bi-Directional Air Flow
12/06/2009 10:33 PM
I would like to know where i can find some literature regarding the S-pitot tube used to measure bi-directional air flow. i have seen S-pitots that measure Stack gas velocities but my aim is to measure the bi-directional air-flow in a very small scale device. so far the smallest recommended diameter for S-type tubes i have found is around 4mm. where as in my case, to avoid a large blockage ratio in the device i have to use a tube of diameter 2mm or less. the tip of my s-pitot would look like this
what do you think. will this work?
(my aim here is to measure the bi-directional airflow in a 30mm diameter pipe).
Thanks
Re: S pitot tube to meausre bi-directional air flow
12/06/2009 11:24 PM
It seems that air/gas flow in either direction will cause readings on both ports. One positive and the other negative. Is the flow turbulent or smooth? Why not make the pitot openings at a 90 deg angle to the flow instead of 45 deg? Maybe I don't understand how you intend to measure the pressure generated.
Re: S-Pitot Tube for Measuring Bi-Directional Air Flow
12/08/2009 5:16 AM
Contact Dwyer- one of the first/ best companies, expert on air flow.
Location: Western flank of the Pennines in Lancashire England
12/08/2009 5:26 AM
I have used a similar technique when measuring low velocities in industrial process air streams. If you connect one impulse pipe to the high pressure connection of an electronic differential micromanometer and the other to the low pressure connection, you will get twice the velocity pressure and the duct pressure will have been cancelled out by being on both sides. Measure the duct temperature and do the normal arithmatic using half the measured differential pressure and you should get a reasonable approximation to the flow rate.
If you use two properly profiled pitot tube tips positioned on the same plane through the duct you will get the best result. It should be possible to get 1mm OD stainless hypodermic tube on the internet. Produce 2 tubes with a radius on the tip and bend them a 90° so that the radiused end is about 10-15 diameters long and then mount both on a plate fixed to the side of your duct.
Ideally you should calibrate the system against a known standard, say a rotating vane anamometer with a calibration certificate.
Good luck and have fun.
Stuart
Register to Reply 3 comments
Anonymous Poster (1); Gasman (1); twomoons (1)
