Previous in Forum: Should You Join ASME?   Next in Forum: High Speed, Reciprocating Transfer Box
Spur Gearbox for Diesel Engine
12/07/2009 2:20 PM
I begin to design 2 set spur gearbox for desil engine with max power of 11kw I make total reduction in the gearbox to be 17.1 , 4.5 in the ferist set and 3.8 in the other , iwant to know is 4.5 reduction ratio is to high or i can use in this case or i must reduce it further more to eleminate wear on the ferist set.
Re: Spur Gearbox for Diesel Engine
12/08/2009 8:53 AM
The ratios are OK and well within tha handling capacity, but check the odd ratios, whether you can have the required gearboxes.
Also it depends a bit on the highspeed shaft RPM.
12/08/2009 5:44 PM
the high speed shaft is 1800 rpm . I am also facing proplem with the material for spur gear with adquant strength , I started with 2.25 as module and 19 as number of teeth .
Register to Reply 2 comments
