Previous in Forum: Durable Red Plastic Substrate   Next in Forum: Sticker / Art Work on Extruded LDPE Foam
Surface Preparation on Hot-Dipped Galvanized Pipe
12/08/2009 12:32 AM
Can any one tell the degree of surface preparation on galvanized pipes in order to apply three coat system as specified in project spec. These galvanized pipes belongs to Firewater services. As we knew that ZINC ASH is an oxide film that develops on the surface of the galvanizing bath, so how to remove and prepare surfaces for further three coats?
Adeel Ahmad
Also posted in: also posted in Manufacturing
Re: Surface Preparation on Hot-Dipped Galvanized Pipe
12/08/2009 7:33 PM
" the degree of surface preparation on galvanized pipes in order to apply three coat system as specified in project spec." should be as specified by the coating manufacturer.
12/08/2009 11:30 PM
Optimal surface preparation on galvanized steel is a light sandblast. Similar to SSPC-SP7 with an angular profile of 0,5 to 1,5 mils. depending on how thick your 3 coat system is.
I would suggest to use instead a 2 coat system using a Polysiloxane ( like Carboxane 2000) as top coat. It will last a lot longer than any polyurethane on the market.
If sandblast cannot be done you can use a water blast to remove all the salts. Then using a primer/sealer (polyamide epoxy) similar to Rustbond at a DFT 1 to 2 mils it will encapsulate the galvanized then you can use another epoxy (barrier coat) and topcoat.
