Previous in Forum: Submarine Engineering   Next in Forum: Total Quality Management
Good Answers: 97
Greenhouse Effect Sounds Like a Great Idea (Part 2)
12/08/2009 10:47 PM
Harrison Brown – a geochemist who supervised the production of plutonium for the Manhattan Project – wrote in his 1954 Malthusian book "The Challenge of Man's Future" that the production of the food needed to feed an increasing world population could be advanced by human-manipulated greenhouse effects, including forcing carbon dioxide into the atmosphere.
This is the first of a three-part series of articles
http://www.wnd.com/index.php?fa=PAGE.view&pageId=118304
Re: Greenhouse Effect Sounds Like a Great Idea part II
12/09/2009 7:20 AM
On the news tonight, a spokesman from the Dept of Meteorology claimed that for the last 70 years, each decade has been warmer than the last.
This is rubbish, because in the 1970's, academic circles were worried about the probability of a new ice age coming because of falling world temperatures!
It appears the AGW proponents are quite happy to "stretch the truth" and manipulate figures as long as it supports their case.
There also seems to be a growing number of scientists who disagree with AGW, so perhaps the tide is turning, just as the politicians have started to trust the scientists and act on their advice (which will probably change shortly)!
Good Answers: 70
12/09/2009 11:41 AM
As I remember this, in the 1970's two scientists, one of the from Stanford, published a paper on the cooling of the earth. The news media ran with the 'new ice age' story because it was sensational. When a short time later the scientists found mistakes in their data, they admitted the mistake publicly at serious cost to their professional standing, and abandoned their theory. The news media wasn't interested in the retraction because it wasn't 'sexy' enough. The global warming denial industry (a subsidiary of the fossil fuel industry) still brings this blooper up to inflame public opinion, against the idea of global warming, and against the scientific community in general.
Good Answers: 97
12/09/2009 7:28 PM
An informative on topic read, you will find this very interesting:
http://nov55.com/gbwm.html
Summary
Global warming is occurring due to oceans heating, not greenhouse gases. The oceans are heating due to hot spots rotating in the earth's core, which is the cause of ice ages.
Oceans regulate the amount of CO2 in the air, as indicated by the chemistry and the stability over time at extremely low levels. Otherwise there would a large amount in the air, and it would fluctuate drastically (like smog does).
Principles of chemistry indicate that regulation by oceans must be absolute. CO2 disolving in water establishes an equilibrium. Equilibrium means absolute regulation.
Production and sequestration of CO2 are totally irrelevant, because they do not regulate. They would leave excessive and highly varied amounts in the air, if oceans were not regulating.
Main Points
The effect of so-called greenhouse gases such as carbon dioxide is extremely minuscule.
1) Only 3% of the CO2 in the air results from human activity.
2) Carbon dioxide is already aborbing all available radiation at its peaks of 2.7, 4.3 and 15 µM; and most of it within 10 meters of distance. Changing the amount of CO2 can only change the distance, not total heat. details
3) The atmosphere is heated by conduction and convection from the surface, but propagandist imply that only radiation is involved.
4) The amount of CO2 in the atmosphere is not determined by production, because it is regulated by the oceans. Cold oceans absorbs more, and warm oceans release more back into the atmosphere.
5) The 30% increase in atmospheric CO2 over the past century indicates oceans heating (due to other causes), and it is too minuscule to be relevant. It is an indicator, not cause, of oceans heating.
6) Air has a much lower heat capacity than water, which means oceans can heat the air, but the air cannot significantly heat the oceans.
7) Water in the air is a greenhouse gas which swamps the others. It is about a hundred times more prevalent than CO2 in clear air, and much more significant on a cloudy day.
8) When el Nino heats the Pacific, CO2 increases in the atmosphere; and after El Nino, it normalizes. It wouldn't normalize if oceans were not reabsorbing the CO2. And if oceans can reabsorb that CO2, they can absorb any other CO2.
9) Global warming has been continuous for about 20,000 years, as always occurs between ice ages, not just the past 150 years which propagandists refer to.
10) Plants need more CO2 to grow on. Their growth increases substantially when more CO2 is provided. The oceans had to be large to aquify the planet, but then they absorbed too much CO2 for good plant growth.
Explanations
Carbon dioxide is called a greenhouse gas because it absorbs infrared radiation, which the earth and atmosphere emit, and converts it into heat. The suns radiation is not involved, because CO2 and most of the atmosphere are transparent gases which do not absorb visible light.
The primary fallacy of this whole issue is the assumption that more CO2 means more heat. It doesn't. More CO2 changes the distance of absorption but not the heat. The reason is explained on the Nitty Gritty Page.
About the first ten percent of the CO2 adds some heat to the atmosphere, and the rest shortens the distance of absorption, while convectional currents mix the results.
If more CO2 were relevant, the "more" would also apply to water vapor. Water vapor is a greenhouse gas which is far more significant than carbon dioxide. There is about a hundred times as much of it in the air, depending upon humidity, and it has a broader absorption spectrum. So it swamps the significance of carbon dioxide.
Since there is about 100 times as much water vapor in the air as CO2, and its absorption bands are at least 3 times wider, it produces 300 times as much of a greenhouse effect as CO2. Even ignoring the methane, nitrous oxide, etc., this means CO2 would produce no more than 0.33% of the greenhouse effect (If the concept of "more" were relevant.). Since both sides agree that the greenhouse effect adds 33°C of heat to the earth, CO2 would not add more than 0.11°C (which is 33 divided by 300).
On top of that, humans are only responsible for 3% of the CO2 in the atmosphere. This means the 0.11°C must be multiplied times 0.03 to get 0.0033°C as the maximum possible human addition of heat to the atmosphere through CO2, when compared to water vapor.
Yet propagandists talk about 3-6°C increase in air temperature (in the future) due human input of CO2. They aren't being honest. They rationalize away the effects of water vapor and rationalize into existence the effects of CO2. There are overriding effects which make their numbers meaningless. It isn't that they gets the numbers wrong; it's that they have no stable basis for getting any numbers which have any meaning in drawing conclusions. Out of a black box of nonsense, they get any numbers they want.
(For several years, both sides agreed that humans were responsible for 3% of the CO2 in the atmosphere. But recently, propagandists have been scrambling the numbers, feeling they can get by with anything, having convinced the public that there is a problem. Recently, some have been saying that humans are responsible for 17% of the CO2. If they were previously wrong by 600%, what are their numbers worth? Even with this number, the human contribution to heat in the atmosphere would not be more than 0.019°C, when considering water vapor with the assumption that more is relevant.)
Scientists cannot easily determine if clouds do more cooling due to reflection of radiation from the sun or more heating due to trapping of heat after it gets to the earth. But measurements indicate more cooling than heating. And measurements show that there are more clouds and precipition in recent times. Clouds totally swamp any effect by CO2.
Concerning carbon dioxide, the amount in the air is unrelated to the amount produced. Ocean temperatures determine how much is in the air. This is because an equilibrium is created at the ocean surface, and it regulates the amount in the air. So if there is more carbon dioxide in the air, it means ocean surfaces are warming.
Propagandists sometimes claim that the oceans are not absorbing the CO2 that humans create. If not, then the oceans are not in equilibrium. If the oceans are not in equilibrium, humans are in big trouble, because there is 200 times as much CO2 in the surface oceans and 7,000 times as much in the deep oceans compared to the amount humans produce. A nonsteady state for such large quantities would swamp the atmospheric effects. The fact that there is so little variation in atmospheric CO2 over the centuries demonstrates that it is regulated. And most importantly, the science of the subject states that absorption of gases by liquids is controlled by concentrations and achieves a steady state.
Then there is the implication that whatever oceans do, it is not fast enough to keep up with human activity. The yearly exchange rate for CO2 by oceans is said to be 16 times the amount humans produce. This means all of the CO2 humans produce in one year could be absorbed by the oceans in 23 days (while it has 365 days to do it).
Relating global warming to weather reports is absurd, because only the air temperature is being measured. But air has a very low heat capacity, and it is a very small percent of the surface mass of the earth. To determine global warming, temperatures would need to be measured for the water, rocks and soil—not the atmosphere.
Only satellites can measure atmospheric temperatures, because they average a large area, while thermometers only measure a few cubic inches of air. Satellite measurements show the air to be cooling slightly due to increased cloud cover which reflects away the suns energy.
In fact, particulate pollution (not CO2) is dimming the sun's energy by increasing the reflectivity of clouds and creating an atmospheric cooling effect equal to 1.5 watts per square meter on the earth's surface, which has been measured. Proponents of the greenhouse effect say that the cooling is over-ridden by CO2 which produces a heating effect of 2.8 watts per square meter; but they cannot measure that effect; they contrive it through computer models. Evidence that they are wrong is that the cooling effect is preventing an equatorial band of moisture from migrating north in the usual way. Nature says the air is cooling, not heating.
Computer models are sometimes used in an attempt to translate weather reports into global warming; but they are totally discredited at the scientific level. The truth about computer models is "garbage in, garbage out."
Measurements of ice at the South Pole show that the ice is thinning where it is over water but thickening where over land. This means oceans are heating up; and the result is increased evaporation and precipitation resulting in more ice accumulating over land. An increase in ice accumulation has also been found over Greenland.
Another indication of ocean temperatures increasing is increased rainfall in the upper plains over the past twenty years. A few years ago, Chicago was flooding due to a rise in Lake Michigan; and another canal had to be built around Niagara Falls to cope with it. The humid air originates in the Pacific Ocean, which must be getting warmer.
What then is the cause of oceans heating? The fact that the past ten ice ages have been precisely cycling at about 100,000 year intervals indicates that the cause is not environmental, which would be highly variable. The most logical explanation is that hot spots rotate in the earth's core. It is logical that there would be hot spots in the earth's core and that they would be in motion. Fluids of any size are never homogeneous in temperature. Heat loss and convection result in hotter areas and colder areas in large fluids, and they move around due to gravity acting upon the differential densities.
Based upon previous cycles, the next ice age cycle is due to begin a cool-down any time, which means within the next few hundred years. The way ice ages work is that heat-up of the oceans causes melting of ice caps at the poles and increased precipitation everywhere. This results is water being drawn out of the oceans and accumulating on land as ice. The see level gets about 400 feet lower over about 80 thousand years. Whether the oceans actually heat up for 80 thousand years, or whether the heat up of the oceans is just a trigger mechanism isn't clear.
Another possible explanation, which was common several decades ago, is that ice at the poles melts in a cyclic manner. This theory is still plausible and consistent with evidence. It could be ice melting at the poles which is causing the oceans to heat up. Regardless, it is the oceans heating, not the atmosphere; and the results have absolutely nothing to do with greenhouse gasses.
Credible scientists know that humans are not the cause of so-called global warming. A few years ago, seventeen thousand of them signed a petition saying humans are not the cause. But since them, propagandists in the media, organizations and bureaucracies convinced the public that it is a scientific fact. Now, scientists dare not speak out, or they could lose their jobs. Only the ones who claim humans are the cause get grants.
Propaganda at Every Turn
Look at how this subject is explained on the web site of the Union of Concerned Scientists. It says this:
The "greenhouse effect" refers to the natural phenomenon that keeps the Earth in a temperature range that allows life to flourish. The sun's enormous energy warms the Earth's surface and its atmosphere. As this energy radiates back toward space as heat, a portion is absorbed by a delicate balance of heat-trapping gases in the atmosphere—among them carbon dioxide and methane—which creates an insulating layer. With the temperature control of the greenhouse effect, the Earth has an average surface temperature of 59°F (15°C). Without it, the average surface temperature would be 0°F (-18°C),---
Scientists have concluded that human activities are contributing to global warming by adding large amounts of heat-trapping gases to the atmosphere.---we release carbon dioxide and other heat-trapping gases into the air. link (See FAQ #1)
Now read the same thing described more honestly:
The "greenhouse effect" refers to the natural phenomenon that keeps the Earth in a temperature range that allows life to flourish. The sun's enormous energy warms the Earth's surface and its atmosphere. As this energy radiates back toward space as heat, a portion is absorbed by a delicate balance of heat-trapping gases in the atmosphere—among them carbon dioxide and methane—which constitute only about 0.05% of the atmosphere. When combined with the other 99.95% of the atmosphere (mostly nitrogen and oxygen), the total creates an insulating layer. With the temperature control of the greenhouse effect, the Earth has an average surface temperature of 59°F (15°C). Without it, the average surface temperature would be 0°F (-18°C),---
They pulled a switcharoo in their description. It is the total atmosphere which heats the planet 59°F (33°C), while they say a "delicate balance of heat-trapping gases in the atmosphere—among them carbon dioxide and methane—which creates an insulating layer."
Not being said by the propagandists is that conduction and convection are involved in the "greenhouse effect," while carbon dioxide is about radiation only. Another misrepresentation is omitting water vapor, which is similar to CO2 in its absorption characteristics, and it is often a hundred times more prevalent.
Here's a news article from Nature saying the part of Antarctica which is over land is acquiring more ice, while the part which is over the ocean is thinning. The reason is because the oceans melt the ice from beneath, but the air is not melting the ice from above, while warmer oceans produce more precipitation.
news on ice sheets
same at Greenland
An expert tried to finesse it saying it is what was expected, but it contradicts the usual theory and substantiates my claim that it is the oceans which are heating, not the air. It contradicts the claim that greenhouse gasses are the cause. The greenhouse gasses are in the air, not the oceans. They heat the air, not the oceans.
They have some interesting ideas.
Register to Reply Good Answer (Score 11)
12/10/2009 12:49 AM
Awesome - GA!
emc_c
12/10/2009 6:55 AM
Dear Sir,
In a time of universal disquiet sadly I do not have the scientific background nor the clinical approach with which you have dissected this greenhouse effect. Your treatise is quite remarkable . It contains arguments hard to refute or, inded : ignore. By-standers like a lot of wheat plains are jostled from one side to another with the winds of : fear . Yet , a majority of voices are clamouring for what could create excessive actions that are going to burden humanity financially . Perhaps with little if any benefit.
The indication of the warming of the ocean through uneven resultant heating of its lower parts , as you indicate of the : earth, is a very : plausible , logical explanation. Many years ago I have witnessed , from an island schooner at close range , an underwater volcano or vent creating over weeks an island where there was nothing previously. When seen at close quarter that force is : awesome . Yet one has to wonder how long this internal and immense source of heat which, for millenium has been contained , can in the future continue to be an element of balance in our :planet. Undeniably and ultimately its lessening intensity will then have effects which will be significant, irreversible . These irreplaceable values will be lost in the balance that nature provides us. Doubtless this is beyond the present argument of : atmospheric warming.
One has to wonder if a : balanced , logical appraisal will now emanate from such a large number of delegates to Copenhagen ? Indeed if cool heads and minds can digest arguments and facts as you have displayed to this community.
Thank you for the clarity of scientific thought.
Labor Omnia Vincit .
Good Answers: 109
12/10/2009 10:16 AM
GA to guest and BLING. I do believe the oceans are the biggest dynamic regulator of CO2. The saturation point of CO2 is lowered as the temperature of the water rises. As the oceans warm the CO2 sequestered by the ocean is released to the atmosphere. What then is causing the ocean's to warm and release CO2? Your remarks on the underwater volcanic activity is often a source of CO2 in the oceans that is overlooked in models on climate. Submerged volcanic tectonic activity is very dynamic and is difficult to apply a numeric value at any given time. ( I read somewhere that the all of the earth's ocean water is recycled by subduction into the earth's crust every million years, ergo salty ocean water). The complication is exacerbated by the possible warming of the oceans. Is the ocean warming man made or part of a cyclical act of nature? Either way the AGW side needs to do more work to convince me that we should be panicked into any drastic action. They need to better define the effects of mans input to greenhouse gases and if they are small then they ought to slow the hype (propaganda).
Good Answers: 109
12/10/2009 10:30 AM
Sorry I meant GA to BWIRE not BLING
Good Answers: 97
12/13/2009 5:28 PM
Thanks...
Good points many are the ways man has acted without regard and contributed to effects which all taken together may seem to restrict natures remedies from producing a cure.
Example:
Construction projects and wanton irrigation causing a plume in the oceans which may cause harm to ecosystems by attrition. Destruction of rain forests and wetlands; colonial America had it's share in that too.
Good Answers: 42
12/10/2009 10:22 AM
Vincit, it seems many times you forget to login. Take care.
Nature is so graceful and naked. Human possession is ridiculous.
12/10/2009 8:31 PM
Guest, GA
Indeed, the earths core is surely slowly cooling, and would we not end up like Mars with a cooled solid core and loss of atmosphere, Ice ages should come more frequently and severely.
I think global warming sounds like a good idea, but is that whats really happening?
Looking forward to the oceans rising so I can have beach front property.
Spacecannon
The person who wrote the above is not resposible for spelling, grammar or puncuation, ......
Good Answers: 11
12/10/2009 8:31 AM
I haven't done much research on this and I really hate saying this because I believe that most global warming talk IS propaganda but http://nov55.com/gbwm.html looks like it is a proganada website too. I really don't think they are very credible after skimming through some of their external links.
Now, I could be wrong because I didn't read much of the text on the site but I pulled this quote from the end.
Cold Fusion: Carbon dioxide is heating the oceans through cold fusion. Half the CO2 humans produce goes into the oceans. This means the oceans are heating by half the global average temperature of 288°K, which is 144°K temperature increase of the oceans caused by humans.
I thought cold fusion was more science fiction than science fact.
Again, I could be wrong about this site having not read it in as much detail as you have but it just seems like propaganda to me.
Good Answers: 97
12/11/2009 3:17 AM
Good Answers: 114
12/11/2009 12:50 PM
I give a 3 cause you can't dance to it
I did like the dimming of the lights & sound effects for dramatic effect
Good Answers: 70
12/10/2009 11:59 AM
GGGGGGGGGGAAAAAAAAAA!
I think I'll mostly keep my 'mouth' shut because this is a really well though out and well presented piece of work. Whether you are right or wrong, this is probably the most thought provoking theory I've seen in a while. Having said that:
  • It is clear from the NOAA maps that the sea surface temperature, at least in the northern hemisphere is several degrees higher than 'normal'. On the other hand I have recently read an article reporting that the subsurface temperatures are actually declining. (I will provide the link when I locate it) This isn't necessarily surprising, since the sea ice at the poles does seem to be melting, and the phase change energy to covert ice at 32 F into water at 32 F means that heat energy from the surrounding water must be absorbed by the ice, lowering the average water temperature in the area. But if as you say the oceans are heated by hot spots in the mantle (like the one that forms the Hawaiian islands?) heating the sea bed, you would expect to see subsurface temperatures increasing, at least in the volume above the hot spot. I would imagine that you could find evidence of this heated plume of water reaching the surface. Here is a link to the NOAA map:
http://www.osdpd.noaa.gov/data/sst/anomaly/2009/anomnight.7.2.2009.gif
  • When the greenhouse gasses (CO2, methane, water vapor, and a number of others) absorb some of the IR black body radiation from the land and sea surface, this heats the atmosphere. As the air heats up, the conductive heat transfer from the sea/land surface to the air should become less efficient, and the ground would become even warmer. I would think that the result would be that the amount of energy gained each day by the earth would then be greater than the amount lost to space.
Good Answers: 109
12/10/2009 1:31 PM
In < www.thefreelibrary.com> you will find an article: "New Type Of Hydrothermal Vent Looms Large" Unfortunately I cannot copy the web directly due to copy rules. Interesting article on subduction of ocean water forming large vents but also carrying ocean waters with an estimated complete ocean water recycle time of 500,000 to 1,000,000 years. This ocean water recycling was known when I studied physical geography 20+ years ago. The recycling provides significant green house gases in the form of CH4 and CO2. It may be that the ocean movement in/out of the mantle is uneven with time. There must be some oceanographers and geo-chemists that could help to clarify this action as an input to global greenhouse gases.
Good Answers: 114
12/10/2009 4:45 PM
Here's a proper link
12/10/2009 4:49 PM
"that the sea surface temperature, at least in the northern hemisphere is several degrees higher than 'normal'. "
How do we know what normal is regarding surface sea temperatures? For instance how long has data on sea surface temperatures been recorded? At least on land we can attempt to estimate past temperatures based on tree rings or other artifacts found that were around 1000 years ago or more. But the sea surface is constantly changing.
J B
Good Answers: 70
12/10/2009 5:36 PM
For most of recorded history people have sailed the oceans. I'd guess that since the time when Italian inventors began building 'thermoscopes', we have been measuring water temperatures. There has to be a pile of captain's log books filled with notes on temperatures in most old sea ports. Most navies also have records going back centuries. I believe NOAA's data is good enough that navigators rely on it, but I'm not vouching for this chart; that's why 'normal' is in quotes. I'm pretty firmly in the anthropogenic wing of the climate debate, but of all the 'denier' stuff I've seen on the net, this seems to be the most rational and fact based discussion yet. Maybe it will stay that way for a while.
12/10/2009 11:51 PM
Granted humans have been sailing about for thousands of years, but only regularly into the open seas (Middle of Atlantic and middle of Pacific) for 500 or so years. Are you telling me that their is sufficient temperature data on sea surface temperatures for the vast majority of the Atlantic and Pacific oceans to be able to make reasonable comparisons to temperatures today? Are there enough samples per site to make the data meaningful? How accurate were the thermoscopes, Since climate alarmists are complaining about a few degrees were they accurate to within less than a degree?
I look at how technicians and engineers use measurement equipment these days and most people seem to fall into two camps....those who believe in and understand the need to calibrate equipment and those who don't. My employer has a calibration lab where all of our test equipment is stored. Each piece of equipment has a cal sticker on it and generally has to be calibrated every year (sometimes more frequently depending on the type of equipment it is). My observation of coworkers indicates that a vast majority of them either are too lazy to pay attention, don't care about the quality of their measurements or are just plain ignorant. If supposedly educated engineers and technicians can't be bothered, I am not sure how confident I am in a bunch of sailors using equipment that's been down dragged around open seas in a harsh environment (temperature swings, salt water, etc.). I have to admit to not knowing about thermoscopes or their use by sailors of the past...so I will try to educate myself on the topic.....and feel free to educate me further if you know more.
J B
Hobbies - Musician - New Member APIX Pilot Plant Design Project - Member - New Member
12/11/2009 9:23 AM
I totally agree with you comments on calibration and accuracy. The very limits of calibration and accuracy have throughout history been the greatest stumbling point of scientific progress. We quote and make simulations based on parametric values from the past that are at the very best "WAGs" . . . Wild Assed Guesses. We automatically take for granted the values used in historical calculations to be within OUR modern calibration capabilities. It took several hundred years before Megellans loss of 24 hours was finally discovered to be that the earth rotates . . . what is a few degrees in temperature . . .
A government big enough to give you everything you want, is strong enough to take everything you have.
Good Answers: 70
12/11/2009 1:03 PM
The thermoscope was an uncalibrated precursor to Fahrenheit's thermometer, which was developed a century or so later.
http://inventors.about.com/library/inventors/blthermometer.htm
I was unclear in this statement, and did not mean that 16th century ship's captains carried thermoscopes to record sea temperatures. But the Italian inventors who developed the thermoscope were apparently curious people, and in my fevered imagination I pictured them using their new inventions to check the temperature of the air, water, and maybe even their soup. Since there was no temperature scale at the time, their data set would be something like: soup is hotter than air, which is warmer than open water. No doubt they already knew that. But it was the necessary first step.
The thermometer is a different story, and became standard equipment along with the telescope, sextant, anemometer, barometer, etc., once they were available. Mariners then as now were seriously interested in the weather, since it was often a matter of life or death, and would have a strong incentive to make the most accurate measurements possible with the equipment at hand. Recording these 'measurements' in the captains log was standard practice. It still is, and with improvements in the equipment, the reliability of these measurements has increased.
Sailors may be comparable in their fastidiousness about using, handling and calibrating equipment to those folks in your workplace that you mention, but these tasks were too important to leave to illiterates. The officers and captains were usually much better educated, and they would be the ones who made or supervised these tasks. I doubt that they had written procedures for calibrating their thermometers, so their accuracy is a legitimate question. On the other hand, I have a mercury thermometer that my grandfather made and calibrated in the 30's. He calibrated it the old fashioned way: ice water and boiling water (at sea level). Last time I checked it it was dead on at freezing, and ~0.5 deg C low at boiling. At 35 deg C it is ~0.6 deg C low. I really have no idea how accurate it is between these points.
So in response to your questioning of the accuracy of the volumes of 'data' in these old log books:
  • I don't think we can possibly answer that question. Common sense suggests that the errors in these old temperature measurements would be random, but that is speculation, not science.
  • I seriously doubt that NOAA relied exclusively or even heavily on old log books to establish a base line. I did find a NOAA page with a bibliography of such things, which suggests that log books may have played some part.
  • I run an independent calibration laboratory, and take calibration very seriously. I don't think this job has existed for more than a couple hundred years. But that doesn't mean that all measurements or scientific discoveries made before then are meaningless. I trust that our ancestors were serious people, involved in a serious business, making the best measurements they could. So I wouldn't bet the farm on their accuracy, I wouldn't want to speculate about their measurement uncertainty, but I don't reject them as worthless.
For a sense of how accurate these old thermometers could be:
http://web.mit.edu/newsoffice/2003/thermometer-0924.html
Good Answers: 213
12/11/2009 12:11 AM
One of the major issues that I and apparently many others have, is the very, very short period of history being used to define "normal". Even if "for most of recorded history" we had accurate sea temperature measurements, these would still only represent a very, very small portion of the history of the climate of earth. The last ice age ended prior to recorded history. What was "normal" between the last two ice ages? We can not say. What can be said is that when one compares the recent "trends" that have so many people alarmed with extended historical trends, there is nothing unique about the current situation. Temperatures have been warmer, CO2 has been much, much higher, and life still goes on.
The earth is supposedly 4.8 billion years old, or thereabouts. Life has apparently existed on earth for about 3.75 billion years. There have been at least 5 major extinction events, and life goes on. I don't remember exactly how many ice ages there have been, but we know that the earth gets hot, then it gets cold again, then it gets hot again. It has been a long, long time since the earth has been as hot as Venus (if it ever was that hot, in the early days while being formed). The earth has never been as cold as Mars (and it will likely be many, many years before the core cools down enough to allow the surface to reach that temperature)...
Modern humans have been around for something like 200,000 years, maybe dominant in certain environments for 14,000 to 18,000 years, more so on a world-wide scale for something like 12,000 years (with the advent of agriculture). We did not start recording things (as far as we have been able to determine) until 6,000 or 7,000 years ago. Even if we had been accurately recording the sea surface temperature "for all of recorded history", this would only represent something like less than 1/100 percent of the time since the dinosaurs supposedly went extinct.
So, how valid are ANY of these "climate records", no matter how accurate they may be, when one is trying to define "normal".
Good Answers: 97
12/11/2009 2:13 AM
Correct insufficient data is the cogent answer on all points.
Good Answers: 97
12/13/2009 5:32 PM
Thanks for contributing AGW is myriad complexity shrouded in assumption.
Good Answers: 80
12/10/2009 12:21 PM
GA!
As other said, this looks like an objective interpretation of what is happening. I believe that the truth is close to what you have presented.
12/10/2009 10:26 PM
You present a commanding argument, but unfortunately you are incorrect. It is true that CO2 absorbs in certain bands of infrared and that mostly the atmosphere is transparent to visible light. This is the mechanism of the greenhouse effect. It is blackbody radiation. The solar radiation mostly passes through our atmosphere heating the mass of the earth (land and sea). The earth in turn radiates back in proportion to its own temperature. This is in the infrared spectrum and precisely why water vapour and CO2 are so effective at changing the transparency of the atmosphere to the infrared.
Don't forget the albedo of the polar caps. These are diminishing pretty rapidly and once they are gone the extra heating due to the absorbtion of additional heat will cause a runaway heating of the planet. The arctic tundra contains a lot of locked up organic matter that will decompose to methane and carbon dioxide. This is going to be an interesting few decades and won't be helped by the ostriches who can't see the elephant in the corner.
Good Answers: 97
12/11/2009 2:30 AM
You present an argument but it is without focus.
Do provide values of your points and present them in context of actual distribution.
Bravo! quite pertinent, as the land based ice accumulation is increasing a balance of cooling will occur.
polar caps. These are diminishing pretty rapidly and once they are gone the extra heating due to the absorption of additional heat will cause a runaway heating of the planet.
This is a contradiction of your previous truth.
Of course this is out of context due the increasing ice accumulation over land.
Good Answers: 42
12/11/2009 11:16 AM
BWIRE,
Based on the website information posting, you could have done some editing or condensing work. The post seems to be too lengthy ,a probable record for the most lengthiest single post in any forum.Could it be so? Based on your prime reading what is your precise conception?
* What I could conceive is that, the so called Global Warming due to green house gases released may not contribute much to effective global warming by fossil fuel burnings. The current version of scientists seems more of an exaggeration.
*Having no simulated or realistic proof findings ,mere prediction based on theoritical modellings may not provide a clear guidance to the issue. That also does not mean that all sayings are irrelevant.
My points in fair support of global warming with no quantification data is based on the following phenomenon.
*There is a constant exchange of heat from air to sea water or land surface water on a daily basis. Hot air when passing over pure or saline water exchanges heat with moisture.
*Solar radiations are absorbed by sea water and the day time heat is more on air and as absorbed heat on water body. There is an equilibrium or alternate heat take up release cycle between air and sea water. That reflects as cool air in night and hot air in day time mainly caused by sunlight.
*The latent heat from sea water develops vapour pressure and all vapour are lifted up in day time leading to the formation of clouds, the saturation levels leads to condensation and rain falls.
*When everything is based on the natural cycle like sunlight based transactions , not much adversities are expected.
*Apart from this part of the heat hitting sea water surface is also reflected back onto space a major solace for all of us.
*Keeping the climate or temperature balance, just apart from the exchange between air and sea water, there is another major contributer which I would like to add are THE ICE MOUNTAINS ON LAND SURFACE AS WELL AS GLACIERS FLOATING ON THE SEA WATER. To me these ice layers give a buffer role in temperature control of the climate..
*Apart from solar heat, man made or natural forest fires, volcanic heats are additions .
*More the carbon into the atmosphere, the particulate matters of carbon absorb IR radiations and add to undissipated heat as is being blocked as smogs or the water vapour present in clouds could also add to heat in the atmosphere. All heat adding dissipations are fossil fuel burnings from transports, thermal power plants , nuclear power plant water discharges, plant heats, domestic heat, air conditioning heat outlets[buildings and transports], Industrial heatings and exhausts, domestic heatings,Heat absorbed and retained by building walls and roofings, black surfaced bitumen/ tar roads and so on. A thermodynamic expert can give better heat data of the above activities which confirms that HUMAN ACTIVITIES ADD MASSIVE HEAT INTO ATMOSPHERE.
*One important point I would like to add is the limitation due to air volume and effective seawater surface area which are almost constant values on the planet.
*That adds to the fact that the carrying capacity of air water heat exchange is disturbed by extra heat additions all other than solar.
*The acidity caused as acid rain is another consolidating point as well as complex catalytic green house gases reactions.
*Green cover by way of massive vegetation is another major absorber and converter of carbon emissions as worth food to all of us.They also absorb heat from air and effectively reduces atmospheric heat. THAT GOES WITHOUT SAYING THAT AS DEFORESTATION AND GREEN COVER IS LAST PROPORTINATELY HEAT IS SEQUESTERED OVER THE PLANET.
All that adds to the relevance of global warming.
*As regard to sea level rise my points are;
*Floating ice bergs are under buoyancy on sea water, won't add much to level rise. What could be bothering is the ice melting from land based mountains.
GLOBAL WARMING IS DIRECTLY PROPORTINAL TO NON SOLAR HEAT AND DEFORESTATION INCLUDING DESERT REGIONS IN WHICH THE SAND ALSO RETAINS LATENT HEAT LIKE SALINE SEA WATER.
Good Answers: 97
12/11/2009 1:34 PM
*Having no simulated or realistic proof findings ,mere prediction based on theoretical modelings may not provide a clear guidance to the issue. That also does not mean that all sayings are irrelevant.
Sayings you mean like these:
The fewer the facts, the stronger the opinion.
Arnold H. Glasow
Errors using inadequate data are much less than those using no data at all.
Charles Babbage
On two occasions I have been asked, 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question.
Charles Babbage
The folly of mistaking a paradox for a discovery, a metaphor for a proof, a torrent of verbiage for a spring of capital truths, and oneself for an oracle, is inborn in us.
Paul Valery
In science, "fact" can only mean "confirmed to such a degree that it would be perverse to withhold provisional assent." I suppose that apples might start to rise tomorrow, but the possibility does not merit equal time in physics classrooms.
Stephen Jay Gould
*More the carbon into the atmosphere, the particulate matters of carbon absorb IR radiations and add to un-dissipated heat as is being blocked as smog or the water vapour present in clouds could also add to heat in the atmosphere. All heat adding dissipations are fossil fuel burnings from transports, thermal power plants , nuclear power plant water discharges, plant heats, domestic heat, air conditioning heat outlets[buildings and transports], Industrial heatings and exhausts, domestic heatings,Heat absorbed and retained by building walls and roofing, black surfaced bitumen/ tar roads and so on. A thermodynamic expert can give better heat data of the above activities which confirms that HUMAN ACTIVITIES ADD MASSIVE HEAT INTO ATMOSPHERE.
I find lumination of the properties involved interesting though without a reality or representation of a minimal atmospheric content of C02 inherent as opposed to the overwhelming contribution of heat retention other components such as water vapor misleading (details you may have over looked
CO2 Absorption Spectrum
There is no Valid Mechanism for CO2 Creating Global Warming
Proof one: Laboratory measurements show that carbon dioxide absorbs to extinction at its main peak in 10 meters under atmospheric conditions.* This means there is no radiation left at the peak frequencies after 10 meters. If then there is a doubling of CO2 in the atmosphere, the distance of absorption reduces to half, or 5m. A reduction in distance is not an increase in temperature. Convectional currents stir the heat around removing any relevance for distance.
Scientists who promote the global warming hype try to work around this fact by claiming something different happens higher in the atmosphere, which they claim involves unsaturation on the shoulders of the absorption peaks. (See Disputed Zone.) The difference due to height is that the absorption peaks get smaller and sharper, so they separate from each other. Near the earth's surface, the absorption peaks for water vapor partially overlap the absorption peaks for CO2, while there is less water vapor high in the atmosphere. Supposedly, separating the peaks creates global warming. There is no credibility to that claim. It is nothing but an attempt to salvage global warming propaganda through fake rationalizing of complexities.
What it means is that climatologists admit there is no mechanism at lower levels of the atmosphere, and their rationalization for higher up is phony. ).
It's important to realize that radiation from the sun does not greatly heat the atmosphere, because the sun must give off high frequency radiation in the area of visible light, which goes through the atmosphere. Something as hot as the sun cannot give off low frequency radiation. Temperature determines frequency. This means that most of the sun's radiation heats the surface of the earth, and then the heat moves from the earth's surface into the atmosphere through conduction, convection, evaporation and infrared radiation. The infrared radiation can be absorbed by so-called greenhouse gasses.
Heat leaves the planet through long wave infrared radiation.
Heat Leaves The Planet Through Long Wave Infrared Radiation
The entire basis of "climate change" hype is contradicted by long wave infrared radiation which is not absorbed by greenhouse gasses.
Heat which leaves the surface of the earth as radiation is supposedly the cause of global warming. But some of that radiation is not influenced by greenhouse gasses. The radiation which is unrelated to greenhouse gasses cools the planet, while the remainder has no significant effect on global warming.
The radiation in question can be divided into short wave and long wave. Greenhouse gasses absorb short wave but not long wave. So long wave goes around the greenhouse gasses to cool the planet, while short wave gets used up within the first few meters of the ground.
Here's a review of the science starting at the beginning: Most of the sun's energy goes through the atmosphere and heats the surface of the earth. The heat leaves the surface through conduction, convection, evaporation and radiation. The radiation which leaves the surface of the earth is called infrared. This means it is lower frequency than sunlight, and therefore it is invisible to humans.
All matter gives of infrared radiation depending upon its temperature. Hotter objects give off more radiation, and it is higher frequency. Colder objects give off less radiation, and it is lower frequency. The earth's surface is not very hot, so it gives off radiation which is too low in frequency to be visible.
The light which people see is not emitted from the earth; it is reflected sunlight. The emitted radiation is lower frequency than sunlight and therefore invisible.
Part of the emitted radiation is absorbed by greenhouse gasses, but not all. Greenhouse gasses absorb narrow bands of radiation, and those bands cluster toward the higher frequencies of emitted (infrared) radiation. Toward the lower frequencies of emitted (infrared) radiation, no absorption by greenhouse gasses occurs.
The lower frequencies of the emitted, infrared radiation escape easily into space, since they are not influenced by greenhouse gasses. They therefore cool the planet. Physicists, including climatologists, contradict this fact and pretend that the planet is cooled by the high frequency infrared radiation which is influenced by greenhouse gasses.
How can physicists be so wrong? They operate in such a dark pit unaccountability to the public that they are accustomed to being wrong. They have rationalized mechanisms which promote their errors. There is a very large error in their explanations for how the planet is cooled. They use the Stephan-Boltzmann constant in an extremely fraudulent way to justify this error.
What they do is apply the Stephan-Boltzmann constant to gasses, when it is only designed to be applied to solids. This misrepresentation is not a small one. It's like designing roller skates to work on sidewalks and then pretending that they will fly through the air.
To explain further, the Stephan-Boltzmann constant is supposed to tell how much radiation is given off by matter at a certain temperature. Solids do not give off radiation easily, because each molecule absorbs radiation so easily that only the outermost skin of a solid will allow radiation to escape. But gasses (like the atmosphere) do not have an outer surface for emitting radiation. Radiation leaves gasses from all points within the gas. Therefore, gasses emit radiation much more easily than solids.
Climatologists pretend that radiation leaves the atmosphere as if it were a solid. supposedly, a certain temperature in the atmosphere causes the right amount of radiation to be emitted to cool the planet by the required amount. But there is no point in the atmosphere where a required amount of radiation escapes. Radiation escapes from all locations within the atmosphere, but only if greenhouse gasses are not absorbing the radiation.
This means radiation goes around greenhouse gasses by leaving the earth at wavelengths which are not influenced by greenhouse gasses. These are the long wavelengths of infrared radiation. Richard Lindzen, an MIT meteorologist and critic of the hype, said satellite measurements show radiation escaping from the earth at long wavelengths which are not effected by greenhouse gasses, which is what should be expected to occur.
Is not the most available method if necessary to curb atmospheric C02 content cultivation of plants. Are plants not far more effective and efficient and most of all quick acting of the removal of atmospheric C02 by photosynthesis rather than continued destruction of the planets natural means without compensation of the model. The more C02 the better the plants and the more food can be produced is a win win, no?
Continuance of the AGW "theory" will cause a debilitating burden upon those members of the global estate which can least afford it; this is unconscionable.
12/11/2009 2:05 PM
Bwire, GA
is there any way to copy your easys to a file on my desk top?
Spacecannon
Good Answers: 114
12/11/2009 2:13 PM
Cut "n" paste onto a blank document.
12/11/2009 3:47 PM
Garthh, thx,
I hadn't tried putting it into a new doc. pg.
Spacecannon
Good Answers: 97
12/11/2009 2:16 PM
When you take stuff from one writer it's plagiarism; but when you take it from many writers, it's research.
Wilson Mizner
From post #1 & #3 click the links or highlight then right click the page and save to text editor.
Good Answers: 97
12/11/2009 3:24 PM
I've just been reminded that others often don't realize when I'm kidding
Good Answers: 114
12/11/2009 4:19 PM
B
I didn't think you were ever kidding
Not so sure about WIS either, Blink & I are trying to determine
Good Answers: 42
12/12/2009 1:38 AM
Very interesting debate on gen-unity of justification of global warming.
*I have a stronger point to argue that the net air volume[ heat exchanger fluid absorber of heat and dissipation to water]and the sea water effective contact surfaces are of constant value. There is a limitation on carrying capacity of this exchange added by human activities.
*The added heat/ temperature is a detrimental fact to plants, plant's photo synthesis[ as seen in deserts],humans and all other life forms. Counter measures like artificial localized climate controls like Air conditioning can only add fuel to the fire, because at the point of use they reduce temperature and emit heat out elsewhere.
*CO2 emissions as pointed out by climatologists can not be the sole reason for global warming.But greenery and deforestation do have a definite bearing on CO2 utilization/ conversion.
*just leaving aside the aspect of CO2, can it be understood that we add to the average temperature/ Heat content of the atmosphere? As per your view, all possible heat radiations can be easily dissipated out to space as IR radiation. To me these IR radiations are the deadliest heat waves a major bothering.
*If the above said justification is true, is there any rate of dissipation by radiation out into space? whether night times and day times make any difference on the rate of dissipation out of these radiations into space? Is the IR radiation out phenomenon is instantaneous and bears a constant value at any given moment?
*According to me the over emphasis on CO2 alone and global warming issue won't suffice for the CLIMATIC ISSUES.
It should also account and have a complex index about-Air toxicity[Co2,Co, NOx,SOx, Hydro carbons, Toxic ants], increased air temperature, acid rain,particulate matter, loss of green cover, ill effects to consumers[ human, plants and animals], need for alternate green energies, our consumption habits having side reactions, non renew ability and so on.
*A strong scientific inter disciplinary discussion and conclusion is a major need of the hour. Till then the issue remains as an unsolved puzzle.
Any way it a worthy debate in CR4 forum. Thank you for the initiation. Regards.
Leaving apart from the fact that you have a record GA [10+2...]admirers behind your support, I just silence down, since my views are just based on common sense and not much into in depth science. I just happened to be an environmentalist and green volunteer.
12/12/2009 7:58 AM
You forget the fundamental that the greater the difference, the greater the rate of exchange.
You also fail to account for the scales involved: Krakatau launched a few cubic miles of solid materials into low orbit, and many thousands of tons of SO, SO2, and later methane and CO2 as ruined vegetation rotted. The atmosphere didn't heat to incandescence even though very dirty coal was the common fuel of the day, and the forced draft fan was not yet in common usage. And that has hardly been an isolated incident given that volcanoes seem to still be an active player on the environmental scene, still behaving badly.
Yes, I've been an environmentalist since before the term was coined because I hunted and fish and enjoy the outdoors just for the sake of it. I don't believe in wasting resources just because I can afford it. I also don't believe in the science of panic, where these doomsday scenarios are presented as a means of furthering some group's social utopian agenda.
As I have stated before, if your compare average temperatures with solar activity, you will find much closer correlations than can be demonstrated by the current batch of alarmists with emissions.
How can you be two places at once when you're actually nowhere at all?
Good Answers: 42
12/12/2009 8:47 AM
Thank you Jerry for the corrective information.It is worth learning.
Good Answers: 97
12/12/2009 11:10 PM
Thank you for kind words and participation in discussion.
I have a conflicting view or interpretation. The heat exchanger is that super cooled area outside of the planets atmosphere.
* Counter measures like artificial localized climate controls like Air conditioning can only add fuel to the fire, because at the point of use they reduce temperature and emit heat out elsewhere
A/C units emit heat, at face value may a detriment but when viewed with the understanding the frequency is not trapped by greenhouse gases should allay all confusion of the matter.
It's not merely my view it is fact, in past millennia we have evidence of greenhouse gas levels ten times that of today.
By dissipation you mean cooling; yes.
Negligible.
It is not phenomenon it is an inherent vehicle of global cooling. The remainder of the question logically answers itself.
Absolutely. It is however erroneous in light of the rectification method chosen albeit cap'n trade being a fools errand.
Thanks
Good Answers: 114
12/12/2009 11:35 PM
So, your saying that creating a market for pollution credits won't work?
Do you think humans civilization is having any effect on the climate[climate change]?
Good Answers: 97
12/12/2009 11:53 PM
Climate change has and will continue to occur at intervals regardless of presence of mankind or his activity. Sure we can salt the atmosphere creating an iridescence which may shield the firma and as a by-product cause diminished winds in the plains states confounding the green wind folks
Or we can manipulate energies and disrupt or cause weather patterns, cause clouds to moderate the temperature of a region but what the consequence is? Do we know? No.
Consider that a change state is disruptive or tumultuous but what could a true greenhouse effect produce after stabilization?
Good Answers: 114
12/13/2009 12:00 AM
That's fine & dandy
but didn't actually answer the question(s)
Good Answers: 97
12/13/2009 2:37 AM
It doesn't effect consumption but it will incur additional costs passed to the consumer so overall is impractical.
Yes but not in the perceived politically correct manner.
12/13/2009 7:57 AM
I have to disagree. Most every economics books I've read indicate that raising the price of something will reduce demand (consumption). By the way, I am not in favor of cap and trade at all.
J B
Good Answers: 114
In reply to #59
12/13/2009 10:01 AM
Is there another method you would support, for reducing harmful [so2 for example] emissions?
From the 1960's forward the EPA has used regulation [stick]
What market driven tool would you support.
expecting profit driven businesses to do the right thing in opposition to their bottom line isn't realistic.
Calling bullshit on the discussion of industrial carbon releases into the atmosphere, stops the bigger discussion of humans impact on our planet & how to mitigate the effect(s).
For better or worse there is an opportunity to have that discussion in a meaningful way, not just in the scientific community, but a much larger audience.
It's been 40 years since the last time these sorts of issues were anywhere near the forefront of public consciousness...
Good Answers: 42
In reply to #60
12/13/2009 10:20 AM
LOW COST,INFINITELY AUGMENTABLE, GREEN ELCTRICITY GENERATION TECHNOLOGY is the sole solution to the issue. It also has no relevance to the non conventional energies of present choice.
Good Answers: 97
In reply to #60
12/13/2009 4:28 PM
Sure starting with; stop kicking the can.
For national security and economic stability, placing area specific restrictions upon use of IC engines, metro, light industrial and urban areas for example. Require the rail industry to comply with emission standards. Replace coal burning power generation with nuclear reactors and micro reactors where feasible.
Haven't any suggestion curbing volcanic releases in fact all mans attempts of reducing SO2 may be frustrated due volcanic release.
The EPA is no more than a political kick ball... administrators believe they can bypass congress but history shows CIA tried and failed.
Bill and Ted had the concept, "be excellent to each other". Does that seem simplistic? It should principles generally are, complex issues are best regulated by simple principles and multifaceted objectives.
Bottom lines don't justify lack of social responsibilities, everyone's accountable to everyone else. Although social responsibility has been pushed aside in the past, it wasn't profitable because the bill is yet to be paid, not paying fines but paying for the clean up, paying for damages to persons and property be it public or private.
I don't espouse socialism...
Correct to 60 years...your catalog of Roger Pinks rants ranks a bullseye here
The era of cheap oil is gone and Nuclear is back to the front burner... when all the associated conditions which arise from the use of petroleum or coal are tabled the idea of cheap oil/clean coal will be forever scorned. Green energies can compete together when the major imposter is removed.
I applaud President Obama for actions taken to minimize the influence of lobbyist. Our leaders need to be present, cognizant of the issues and approachable.
Do remind if I've neglected a question
Good Answers: 114
In reply to #65
12/13/2009 10:57 PM
So2 was just an example that popped into my head
We in the same neighborhood, judging by your opinion of coal...
Then you have to go the extra mile
Nukes are non starters, no real resolution of the issues of mining/refining the ore, plant safety, waste.
A simple question would you send your daughter work in a plant maintaining the equipment?
How are you going to quantify the cost of social irresponsibility?
having corporations & other non human entities enjoy the same rights as people, makes it impossible. Corporations are only responsible to increase the value of the stock. your tannery ruins the water shed, go bankrupt [WR grace I think]!
Good Answers: 97
In reply to #76
12/14/2009 1:22 AM
The processes have changed, I'd like a micro reactor in my yard and the daughter can play with it if she wishes
Whatever it takes, if shtf clean it up...if the incentive is appropriate the matter will be handled appropriately...Companies will not bankrupt themselves.
Corporations are non-entities but the managing directors should be liable...if SH on your watch — clean it up or go to jail, don't pass go.
Good Answers: 114
In reply to #77
12/14/2009 1:29 AM
& how is that different than regulation?
A micro reactor may be as safe as you claim
Still haven't accounted for the other 2/3rds of the process
sidebar:
shouldn't yuval be on sp3?
Good Answers: 97
In reply to #78
12/14/2009 1:35 AM
yuval should be on Vista
eh? Deregulation was the beginning of this debacle, everything in moderation is key
Good Answers: 114
In reply to #79
12/14/2009 1:55 AM
well you know how I feel about vista, like linux the more I use it... I'm on mr XP at the moment, which had some strangeness when sp3 1st came out. I was using Ms vista earlier, still don't see any advantage that isn't hardware related, tryed the security tool you suggested, didn't find any problems.
Which deregulation? I don't see either a carrot or a stick without EPA
Good Answers: 97
#81
In reply to #80
Re: Greenhouse Effect Sounds Like a Great Idea part II
12/14/2009 12:24 PM
Vista was designed for me deal with it
Repercussions of a society without personal responsibility.
Good Answers: 114
#83
In reply to #81
12/14/2009 1:19 PM
Oh you're the one you on 7 yet?
Personal responsibility is great
I believe [preaching to the choir]
money talks, retoric walks
How do we even get to the point of having that discussion as a society.....
Good Answers: 97
#84
In reply to #83
12/14/2009 1:40 PM
No 7 for me I haven't a need for it's advantages yet. Several customers want it now! I oblige them, some will use 95, 98, XP or Vista forever however long that is. I'll get 7 eventually, maybe I'll inherit it.
Instilling the ideals start when we are very young, pre-school or there abouts. It's a value the cultural revolution removed from the underpinnings of our society.
Good Answers: 114
#87
In reply to #84
12/14/2009 4:39 PM
Cultural revolution?
last I checked, that was a chinese phenomenon
In reply to #60
12/14/2009 8:49 PM
I am assuming that your post was really meant as a reply to someone else's other than mine as mine was primarily about economics regarding the effects of raising prices on something.
However, since I did mention cap and trade and my lack of enthusiasm for it here is one reason I don't like the idea of cap and trade: http://www.telegraph.co.uk/earth/copenhagen-climate-change-confe/6778003/Copenhagen-climate-summit-Carbon-trading-fraudsters-in-Europe-pocket-5bn.html
Note this quote from the article:
"It is estimated that in some countries, up to 90pc of the whole market volume was caused by fraudulent activities," a Europol spokesman said, after Britain, France, Spain and the Netherlands brought in emergency VAT suspensions on carbon allowances to limit the fraud this year.
In any system of regulation there is bound to be some fraud or cheaters. If it was 10%, I wouldn't be surprised and would expect something like that. However, when it gets to 90%, it's not just the regulating system that is at fault it those running, those who are supposed to monitor it. It should never have gotten to 90% fraud to begin with.
J B
Good Answers: 114
#89
In reply to #88
12/14/2009 9:56 PM
I missed, I meant to reply to #58 [Bwire]
In reply to #89
12/15/2009 12:21 AM
No problem. I'm always happy to get a reply to one of my comments....even if it wasn't intended.
J B
Good Answers: 97
#91
In reply to #88
12/15/2009 12:34 AM
We're on the same page...
I'd expect little else since the basis is fraudulent. At other times cap'n trade would be considered corruption which of course it is.
Good Answers: 97
In reply to #59
12/13/2009 10:26 AM
Perceived in a simplistic manner though not meaningful due the trickle down vehicle of costs passed to the consumer. It's a thinly guised theft from society with progressive intent.
Science/Engineering has produced evidence and methods to change the way we use resources, adoption of advanced technology and return to others abandoned in the past is the way strong intelligent beings react to conditions; not a spurious money grab.
Good Answers: 213
In reply to #59
12/13/2009 11:01 AM
JBTardis-
In spite of what the economics experts will tell you, my experience in every business that I have ever been involved in has worked exactly the oposite. Increasing my prices has generally resulted in increased business volume, and improved the "quality" of the customer base. I do not understand why I have experienced this, but it has been consistent. I suspect it has something to do with people have no concept of real value, but, rather, base their perception of value on what they have to pay for a good or a service. If one positions oneself in the market as the most cost-effective solution or source, one attracts the bottom fishers, who are going to try to negotiate the price even lower or quickly jump ship as soon as one of your competitors lowers his price as well. I have also discovered that many clients enjoy "bragging" about how much they had to pay for a service- noting that, even though the price was exhorbantant, the desired solution was achieved. This actually turns out to be the best sort of word of mouth reference you could hope for, drawing more customers who are less likely to try to negotiate the price down to a point where it is no longer practical for you to pursue the business...
Don't believe everything the economists tell you...
In reply to #64
12/13/2009 8:59 PM
CWarner,
I believe on a micro economics level you are correct. However, I think it's different on the macro level. When the price of gasoline goes up...do you see people buying more gasoline? Yes, you might in the short term as people may be stocking up because they believe tomorrow's price will be higher than todays. But in the long term if you double the price of gasoline, the population will purchase less fuel. If you double the price of labor (i.e. minimum wage) it tends to reduce the number of people employed in a free, or nearly free, market economy. The price increases I'm referring to should be considered the 'real' price, as opposed to 'nominal' price. For instance, if inflation causes all prices to double and eventually salaries to double then everyone has the same purchasing power. But when something causes the price of a good to increase substantially (>10%) all other things being equal, the consumers will generally consume less of it.
If you apply your observations of your own experience to most products in the market today why would a corporation not just keep increasing it's price then? Why do airlines offer reduced fares, if not to sell more seats? Why don't they raise the price of their seats if that will bring in more customers?
J B
Good Answers: 213
In reply to #71
12/13/2009 10:09 PM
I do not fully understand why raising my prices increases volume...I just know that it does (I will admit that I do not increase my prices arbitrarily, and when I do, it is because my margins are not keeping up with the cost of living). I leave that to the annalists to sort out.
With regards to doubling of gasoline prices, which occurred here in Panama not too long ago, it did not seem to have an impact on how much people were driving, but it did encourage a lot of people to change over to natural gas as a fuel. Unfortunately, the price of gasoline did not stay high enough for a long enough period to do any real good...
In reply to #74
12/13/2009 10:22 PM
I don't know why your volumes increased either....it could be perhaps a perceived better value on the customer's part. Or it could be that something else changed external to you that you are not aware of (competitor increased his price by more than yours, more customers desiring your product (meaning you may have seen a volume increase if you had kept your prices fixed).
With regards to doubling of gasoline prices,..... but it did encourage a lot of people to change over to natural gas as a fuel
I think this proves my point. Price of gasoline went up, people found an alternative to gasoline (natural gas) so they could continue what they desired doing (driving). That means the consumption of gasoline had to fall.
J B
Good Answers: 213
12/13/2009 10:49 AM
1. Creating a market for pollution credits is going to have a destabilizing effect on the economy, because you are essentially creating "wealth" out of nothing. Similar to repackaging toxic loans to create the illusion that they are less risky when disguised as something else.
2. I would be very surprised if someone were to "prove" that human civilization had no impact on the environment/climate. Every form of life that has ever existed on earth has extracted resources from the environment, and excreted waste into the environment. This is the process of life. Left unmolested, any population will grow beyond the carrying capacity of the environment (i.e., to the point where demand for resources exceeds supply) and ultimately poison its own environment (unless there is a complimetary species that utilizes the waste stream as a primary resource). Humans are no different, and thanks to modern sanitation practices, modern medicine, and the elimination of major human preditors, human populations are growing unmolested.
3. The current "climate change" fiasco is based on information from a far too narrow window on the data, and the records cited do nothing to identify what is "normal" with regards to temperature and CO2 content. Both have been significantly higher in the past than current "worst case" scenarios predict, and the correlation between CO2 and temperature is not as clear as the "climate experts" claim.
4. Long before the "catastrophe" projected by "climate experts" will have an irreversible impact on human society, other problems (disease epidemics, hunger, thirst, and war intended to mitigate the effects of these crises) will decimate human populations throughout the world. Limited resources are better directed towards mitigating real threats to human well being than to invented "crises" that are politically motivated by wealthy societies as a means to maintain their superior position in the world economy at the expense of poorer nations.
5. A whole lot of good can be done by reforestation. I am often chastised for my preference for this "solution" to a non-crisis, but I offer these arguments in favor:
-It can do no harm
-It is a quicker and less expensive means of sequestering CO2 than any of the proposed alternatives
-It offers employment opportunities to those most in need of meaningful employment
-It improves the capture of water in reservoirs suitable for human exploitation, and may actually improve the water cycle dynamics through transpiration
-It makes the world a prettier place for all sorts of life forms, not just humans
-It creates additional resources for our decendents to exploit with impunity (assuming they continue with the reforestation philosophy).
All in all, global warming is a whole lot better idea than the alternative, which is global cooling (i.e., a new ice age), for all inhabitants of earth. Climate is not and can not be a static process. It will change. If it isn't getting warmer, then it must be getting colder...
Good Answers: 114
In reply to #63
12/13/2009 7:25 PM
So how is cap n trade any different than any other IPO?
Rich people love to gamble a bit of it will trickle down to reducing toxic emissions.
I completely agree that reforestation is a very good thing. In these parts logging & replanting with almost exclusively ponderosa pine, has reduced biodiversity. which is yet a different discussion.
I don't think copenhagen, will bring about any substantive agreements.
I don't understand what you mean?
Good Answers: 213
In reply to #68
12/13/2009 7:33 PM
The whole climate brouhaha appears to me to be a scheme to keep poorer nations (i.e., China, India, Russia, Brazil, etc.) from catching up with the richer nations by limiting their access to the tools of development formerly used by the rich countries, but now considered unacceptable (among these tools, heavy use of fossil fuels to provide cheap energy, and deforestation to open land for development, agriculture, and the like)- "We did it when it was our turn, but now we think it is a bad idea. So you have to find a new road to riches rather than copy our example."
Good Answers: 114
In reply to #69
12/13/2009 8:37 PM
Something like the so called free trade agreements?
which appears to have consolidated the power of the largest corporations...
Good Answers: 213
In reply to #70
12/13/2009 10:03 PM
Exactly...
In reply to #63
12/13/2009 9:00 PM
  1. Agreed
  2. Agreed
  3. Agreed
  4. Agreed
  5. Agreed
  6. Agreed - oops...got carried away.
J B
Good Answers: 42
12/12/2009 11:56 PM
Thank you BWIRE for the caring and educative reply. I could rethink about my conceptions.
*I have a notion that the heat present in air is being exchanged with saline sea water[ which is a good absorber and retainer of heat], like a natural AIR CONDITIONER. The flow of air being restricted to natural forces, the rate of contact and exchange rate having a limitation value.Cool breeze after sunshine actually originates from sea water surface in view of the moisture content?
* The extra energy required for the operation of AIR CONDITIONING equipments can add to heat energy by way of thermal power generation requirement.
* Some amount of serious exaggerations are inevitable ,towards changing consumption habits of public and this seems one among that. Smart customers question values based on true scientific realities.
BWIRE can spearhead the discussions and bring forth solid conclusions. Best wishes.
Good Answers: 97
12/13/2009 2:26 AM
Water is significant in heating/cooling effect to air but air isn't significantly effective in heating water.
I haven't apprehension of this statement.
Smart customers question values based on true Smart customers question values based on true scientific realities.
http://www.youtube.com/watch?v=5_T7FTIFyAA
12/11/2009 5:04 PM
Looked up your article reference, Gary Novak is a microbiologist not a meterologist. It might be a good idea to stick with people trained in the field unless you would like a auto mechanic to do your surgery!!
Good Answers: 97
12/11/2009 5:29 PM
Meteorologists have intense study of the 10 meter altitudes do they??
Good Answers: 213
Re: Greenhouse Effect Sounds Like a Great Idea (Part 2)
12/10/2009 12:14 AM
There are those of us who would prefer a warmer world...Such is a whole lot more attractive than a colder world.
If one looks at a globe, one notes a significant imbalance in land mass between the northern and southern hemispheres; more importantly, a great deal of the land in the northern hemisphere (especially at the centers of the major land masses) is too cold for conventional agriculture. The human population continues to grow, meaning we need more land to feed all these extra people. It seems a good idea that we warm up some of these northern lands to the point where we can grow more food...
The Artic Ocean is rapidly opening up to ocean traffic- bad for those of us who live in Panama, but a boon to the rest of the world, in that it will take a significantly shorter time (read $$$) to move manufactured goods from Southeast Asia to the North Atlantic region- price savings for all you Europeans out there.
So here are three reasons off the top of my head why global warming sounds like a pretty good idea (I'm not sure I am ready to say it is a GREAT idea, but at least it is a pretty good idea)...
Good Answers: 42
12/10/2009 9:04 AM
Assuming that the base energy is from fossil organics, the crops or plants consume major carbon emissions[CO2] and convert into useful food. What best humanity can contribute is to permit and promote green cover over the planet. We are going the reverse way. Augment ability of food crops is the gift of nature for all beings on this planet and may not count much for carbon garbage ,since plants ensure positive convertibility.
12/10/2009 1:27 PM
So the question becomes . . . does it really matter? If the place gets colder . . . or hotter . . . technology adapts and we as engineers benefit. Should I care that the cesspool that a person in Bangladesh lives in gets washed in to some ocean . . . should I care that some island in the ocean is alluviating away . . . or that penguins in the Arctic have to climb up a steeper ice wall . . . the results will ultimately benefit man . . . the sales, marketing and finance say it will happen . . . why fight the money? Cold money . . . hot money . . . it's still money for someone to steal.
Good Answers: 114
12/10/2009 7:08 PM
I mostly agree with your points nukesub
It does matter if we are like Wiley coyote & have run off the side of a mountain & realize the bottom of The Grand Canyon is 1000 feet below
There are gonna be winners & losers.
You can stick your fingers in your ears & go LA LA LA all you want, things are gonna change.
The chinese & Indians are moving towards a lifestyle more like the western world's
& that requires more energy.
We can be part of the solution or ignore it & hope everything works out for the best
Regulating emissions isn't bad
or is there someone who will advocate for pollution?
Increasing efficiency isn't bad
or would someone like to argue for wasting resources?
There's gonna be winners & losers
There's gonna be corporate welfare
Taking the chance that there is a component of climate change related to humans & that we can do something to mitigate the effects, is not going to ruin the economy.
Don't like government regulation, what is the market driven plan?
We can just wait until the chinese & oil barons try to forclose
12/10/2009 8:42 PM
And with change is really what has everyone up in arms, resistance to it anyway. Nothing creates more heart burn for an engineer than to have to take a "perfectly" functioning component, system or plant and make it so that it works less efficiently. To spend money on what has traditionally been an acceptable cost . . . consider the clean up of the Great Lakes in the 1970's and 80's, or the super-fund sites . . . those projects became necessary and monetarily acceptable because of changes in socio-economics. While the polution or damage was being inflicted everyone, including all the engineers, were not at all concerned, it was simply the way things had been done before. Now we see changes in what is acceptable in other areas. We need to look at these changes in a progressive way and accept the fact that we will just have to continue being good engineers and learn new ways to apply our talents.
Good Answers: 114
12/10/2009 9:04 PM
If you do a search or two you'll find a long history of "discussion" on the subject of Climate Change [ for instance ]
Welcome to CR4
Enjoy
12/11/2009 6:15 AM
The problem lies with bureaucrats and politicians who have no technical expertise, but are motivated by the need to justify their existence by creating more rules for the rest of us to follow.
A place where I had lived originally had an open air dump, quite common. In the 1970s, a new dump / recycling center was opened that was EPA state of the art. Due to changes in the rules, it is now a Superfund site that has bankrupted several businesses whose only crime was to follow the rules in good faith.
Good Answers: 213
12/10/2009 10:47 PM
"Taking the chance that there is a component of climate change related to humans & that we can do something to mitigate the effects, is not going to ruin the economy."
Garthh-
This is EXACTLY the problem. Most of the schemes being bandied about by the climate controllers most likely WILL bankrupt society. I don't have the numbers in front of me, but have a look at how much is being spent on the carbon capture and sequestation project under way in Illinois right now- and look at what they are projecting for how much good this will do. Then have a look at the California scheme to beam solar power to earth from outer space. Read some of the proposals about seeding the atmosphere, or "tuning" the oceans with iron shavings. Not only is there no guarantee that the results will even come close to what they are hoping for, there is a very good chance that the results they get will make the situation worse, and we will have to spend even MORE money correcting for these errors.
First, let us put this whole concept in perspective (Anonymous Hero posted a couple of graphs on the previous blog that really show how shaky all this "science" behind climate change really is). Then, let us figure out how to adapt. Meanwhile, if we can clean up the air pollution (the really nasty stuff, not the natural stuff), maybe plant a few more trees, we will all be better off, and it will probably cost a whole lot less money.
Good Answers: 114
12/11/2009 12:06 AM
Charlie do you really think any of the wilder schemes will actually get out of the testing phase?
Rich people always gamble, is investing in say carbon capture or extraterrestrial microwave transmission worse than betting on the stock market? [ok I wouldn't personally invest in either]
We agree that focusing on goals that are actually possible will have the most positive effect.
Climate change is a better talking point than energy efficiency, pollution or deforestation & has gotten more traction on both sides...
12/11/2009 7:32 AM
I am not so sure that the politico or academian is very much aware of the real world . . . I am not sure at all that from the persecptive that they function that they truly can be . . . the politico is perhaps aware of the desires of his constituents . . . and academia aware of the need to emphasize education . . . being that both of these create. Both in their endeavors to remain on the edge of sociological demands, one because changing tradition, the other because of the ever increased pressure to expand the scope of human knowledge, thus neither find themselves in the midst of reality. The politico must ever strive to prove worth to the people he serves, the academian to prove worth to his peers. Thus comes the symbiotic relationship of the technological world. Nothing can be more fulfilling to a poltico than to find a scientist that will stand up beside them and espouse to his perspectives. Thus to the scientists comes the needed support to be politically in vogue.
The engineer on the other hand is in the world of reality. So now we are faced with making our projects poltically correct. Amazing now that industry that was once all technology, will now include the "landscape engineer", the botanist, biologist . . . is there any reason that a power plant (my area of expertise) can not look like or ACTUALLY be a golf course, a nature preserve, a lake becomes partially dedicated to algae production . . . Do we have to do it UGLY . . . maybe in the past . . . efficient expenditure demanded it . . . the concept of efficiency is changing. Who really cares about the cost to consumer anyway . . . the consumer is the one who controls their own costs . . . the consumer when living outside their means . . . must take the necessary action to "escape from affluence" . . . as we see millions of mortgages being simply walked away from . . . so will come the day when some will have to walk away from the traditional electric power utility (solar, fuel cells, wind . . . the alternatives are not coming . . . they are HERE!!!) The momentum of change is CHANGING!!!
Good Answers: 97
12/11/2009 12:38 PM
GA...
quotes
Arnold H. Glasow
Charles Babbage
Charles Babbage
Paul Valery
Few tragedies can be more extensive than the stunting of life, few injustices deeper than the denial of an opportunity to strive or even to hope, by a limit imposed from without, but falsely identified as lying within.
Stephen Jay Gould
Science is a first-rate piece of furniture for a man's upper chamber, if he has common sense on the ground floor.
Oliver Wendell Holmes
Science without religion is lame, religion without science is blind.
Albert Einstein
What is a scientist after all? It is a curious man looking through a keyhole, the keyhole of nature, trying to know what's going on.
Jacques Yves Cousteau
The main reason for the failure of the modern medical science is that it is dealing with results and not causes. Nothing more than the patching up of those attacked and the burying of those who are slain, without a thought being given to the real strong hold.
Edward Bach
Science is a way of thinking much more than it is a body of knowledge.
Carl Sagan
Our scientific power has outrun our spiritual power. We have guided missiles and misguided men.
Martin Luther King, Jr.
Scientific theory is a contrived foothold in the chaos of living phenomena.
Wilhelm Reich
The cloning of humans is on most of the lists of things to worry about from Science, along with behaviour control, genetic engineering, transplanted heads, computer poetry and the unrestrained growth of plastic flowers.
Lewis Thomas
The most exciting phrase to hear in science, the one that heralds new discoveries, is not 'Eureka!' but 'That's funny...'
Isaac Asimov
There is one thing even more vital to science than intelligent methods; and that is, the sincere desire to find out the truth, whatever it may be.
Charles Pierce
Wilson Mizner
You cannot feed the hungry on statistics.
Heinrich Heine
— Orson Welles
Criminals are never very amusing. It's because they're failures. Those who make real money aren't counted as criminals. This is a class distinction, not an ethical problem.
Man is a rational animal who always loses his temper when called upon to act in accordance with the dictates of reason.
12/11/2009 6:07 PM
I agree generally with your first paragraph. The only thing I would add is that there is an increasing number of academians that are more interested in indoctrination to their convoluted way of thinking than in education. (Don't bother me with facts, my mind is already made up!) They are the hybrid politicians. The politicians are just hypocrites in general; do as I say and not as I do. So now they have discovered this symbiotic relationship and they're exploiting it for all it's worth.
Your second paragraph I don't foresee in the immediate future. Look how long it took to fully electrify the country, put a telephone in 'every' home, and we still don't have cable or wireless everywhere. Yes the new technology is here, but it is beyond the reach of those who most need to drop off the grid.
Everyone I know who has installed solar, windmills, gensets, et-all, has done so to spite the utilities and try to save their money; not out of any concern for the environment, or as a matter of survival. They're just fed up with a self-serving system that respects no one and abuses everyone in general.
And again, for what it's worth, a better case can be made for global cooling than warming, and none of it from mankind's activities given the relative scales involved.
12/11/2009 8:42 PM
Dear Sir(s)
Some , in fact most , of the discussions are, indubitably : sound. All merit deep reflection. They vary from : natural observations to the methaphysical . In many ways and by their immense complexities they illustrate that humanity does not require a President as a Nobel recipient . What it deserves , in fact , needs, is : a new Einstein to synthesise the myriad of varied and divergent thoughts. Am I to say for my fellow Engineers that we, as a whole ,have reached the point where giving a single direction is beyond our : ability or training ? Are we to admit that when so many have sworn that super computers could solve the vast expanse of conflicting data same could be done in a few hours , these same experts are now silent on : warming ?
Whether we are believers or disbelievers in the surface warming and prove or disprove the changes. Whether or not we prove or disprove that : Cook, Magellan,Quiros, Mendana or Vasco de Gama erred in their interpretation of archaic or : pre-historic means of temperature observations are , in reality : esoteric , and perhaps, futile discussions.
Without the intentions of causing or creating diversion, I remain deeply perplexed by the lack of educated thought or predictions based on the realities of the past in the mining sectors that have depleted our planet irreversibly. I refer here to :
1.The huge extraction of: oil
2.All ores including iron ores
3.All fossil fuels other than oil i.e mainly :coal.
Where are such quantities as recorded in : mining records. These , more than likely , will be more credible than surface water temperature recorded 3 or 4 centuries ago. Are we to blithely consider that the loss of the weight is compensated by greater human numbers ?
Who will then say , publicly, whether this continuing change in the mass of the earth will not : far more, and indeed : far more quickly, modify ( by eventual eccentricity of : its mass ) the trajectory of the earth ? Either towards the : Sun or away from it ? Can any one say that this, in itself , may well become much more irreversible than whether or not we sequestrate CO2 ?
Let not the quagmire of diatribe swallow up thoughtfull discussion . Instead be the alert signal of action and concern : for our descendants.
Labor Omnia Vincit.
Good Answers: 19
#92
12/15/2009 6:59 AM
Are you serious or is this a little joke? mass can neither be created nor destroyed, all the stuff we dug up (with the exception of the odd spacecraft) is still here. We are also accreting mass due to incoming space debris.
Good Answers: 213
#93
In reply to #92
12/15/2009 12:56 PM
Don't forget the gases that are being blown off the outer atmosphere by the solar wind...
#94
In reply to #92
12/15/2009 6:39 PM
Dear Sir,
Magnetite, ilmenite or any other form of iron ore has to be melted. Kindly consider whether one tonne of such ore still weighs 1000 kilos after it has been melted ? Point one. That same kilo of steel or iron that has been produced , if left in the atmosphere : corrodes. ( where it loses less of its weight is where air does not corrode it .i.e under water) The process of : corrosion ,admitedly much slower, is inevitable.
In the above process please consider that the amount of coal that has been consumed to smelter the above has been burnt . Whilst that needs to be checked with the residuals of coal i.e. bottom ash and fly ash, which do retain their weight ,please note that: 1000 kilos of raw coal does not equate 1000 kilos of residues after : burning. Results may vary, but mass has been forever lost in the main as : emission and propagation of heat.
The above loss of mass of : oil (wherever or however it is consumed) is even more telling. It goes to the core of this link and, all combined , contributes to the warming of the atmosphere .
In conclusion could I say that the heat of the arguments generated which have and are : gracing these pages should , in my view , add to the unfortunate but undeniable warming of this planet.
Labort Omnia Vincit
Good Answers: 213
#95
In reply to #94
12/15/2009 6:56 PM
It appears to me that your perception of the laws of chemistry and physics is very distorted...
Combustion does not result in the destruction of mass. When you "burn" something, a major part of the mass is oxidized (i.e., combined with oxygen) to form another product, such as carbon dioxide.
Similarly, corrosion is just another form of oxidation- i.e., iron is converted to iron oxide.
The energy derived from such reactions is the result of the breaking of chemical bonds...
Just melting something is not going to change it's mass. One may separate some mass from other materials (i.e., iron from slag when melting impure iron), but the sum of all the masses at the end of the process will equal the sum of all the masses at the beginning of the process.
Unless, of course, one is considering nuclear reactions, in which case a small amount of the original mass is converted into energy...
Good Answers: 97
#97
In reply to #95
12/16/2009 12:41 AM
Be Careful Out There:
IDIOT SIGHTING:
We had to have the garage door repaired. The Sears repairman told us that one of our problems was that we did not have a 'large' enough motor on the opener. I thought for a minute, and said that we had the largest one Sears made at that time, a 1/2 horsepower. He shook his head and said, 'Lady, you need a 1/4 horsepower.' I responded that 1/2 was larger than 1/4. He said, 'NO, it's not.' Four is larger than two..'
We haven't used Sears repair since.
IDIOT SIGHTING:
My daughter and I went through the McDonald 's take-out window and I gave the clerk a $5 bill. Our total was $4.25, so I also handed her a quarter. She said, 'you gave me too much money.' I said, 'Yes Iknow, but this way you can just give me a dollar bill back.' She sighed and went to get the manager who asked me to repeat my request. I did so, and he handed me back the quarter, and said 'We're sorry but they could not do that kind of thing.' The clerk then proceeded to give me back $1 and 75 cents in change..
Do not confuse the clerks at McD's.
IDIOT SIGHTING :
I live in a semi rural area. We recently had a new neighbor call the local township administrative office to request the removal of the DEER CROSSING sign on our road. The reason: 'Too many deer are being hit by cars out here!
I don't think this is a good place for them to be crossing anymore.'
From Kingman , KS .
IDIOT SIGHTING IN FOOD SERVICE :
My daughter went to a local Taco Bell and ordered a taco. She asked the person behind the counter for 'minimal lettuce.' He said he was sorry, but they only had iceburg lettuce.
From Kansas City
IDIOT SIGHTING:
I was at the airport, checking in at the gate when an airport employee asked, 'Has anyone put anything in your baggage without your knowledge?' T o which I replied, 'If it was without my knowledge, how would I know?' He smiled knowingly and nodded,
'That's why we ask.'
Happened in Birmingham , Ala.
IDIOT SIGHTING :
The stoplight on the corner buzzes when it's safe to cross the street. I was crossing with an intellectually challenged coworker of mine. She asked if I knew what the buzzer was for. I explained that it signals blind people when the light is red. Appalled, she responded, 'What on earth are blind people doing driving?!'
She was a probation officer in Wichita , KS
IDIOT SIGHTING :
At a good-bye luncheon for an old and dear coworker. She was leaving the company due to 'downsizing.' Our manager commented cheerfully, 'This is fun. We should do this more often.' Not another word was spoken. We all just looked at each other with that deer-in-the-headlights stare.
This was a lunch at Texas Instruments.
IDIOT SIGHTING
I work with an individual who plugged her power strip back into itself and for the sake of her life, couldn't understand why her system would not turn on.
A deputy with the Dallas County Sheriffs office, no less.
IDIOT SIGHTING When my husband and I arrived at an automobile dealership to pick up our car, we were told the keys had been locked in it. We went to the service department and found a mechanic working feverishly to unlock the driver side door. As I watched from the passenger side, I instinctively tried the door handle and discovered that it was unlocked. 'Hey,' I announced to the technician, 'its open!' His reply, 'I know. I already got that side.' This was at the Ford dealership in Canton , MS
STAY ALERT! They walk among us... and the scary part is that they VOTE and they REPRODUCE.
Good Answers: 213
#98
In reply to #97
12/16/2009 1:01 AM
OK, OK...You proved your point, bwire. Maybe the Guest above wasn't so far off base as I accused him of being, in light of these other examples...Population control looks more and more attractive every day.
Good Answers: 97
#102
In reply to #98
12/16/2009 6:20 PM
Nah I think were not for grace there go I, we need those people too, many are the occupation's or job descriptions.
Ironic China would claim a manpower reduction due to the one child policy may take three generations to turn around. Then a year later ascribe population control to the rest of the world
I understand rare earth is getting to be rarer too at least what's allowed as an export from China. Curious how the green stuff will fair without availability of certain components.
Good Answers: 213
#103
In reply to #102
12/16/2009 9:37 PM
China is a good example of what can go wrong with poorly-conceived population control methods- now they face the same problem as the rest of us- aging population with insufficient workforce to pay for all the social benefits promised to the retirees...And I also am not to fond of Stalin's or Hitler's style of population control either...Soylent Green has some possibilities...
I have been concerned about China's restriction on the exportation of rare earths as well- especially lithium. The only major deposit I know of outside of China is in Bolivia, and Evo Morales is not about to let major world enterprises in to extract the lithium- he wants to mine, refine and manufacture batteries all within Bolivia- with apparently limited technical resources within the population (kind of like Chavez trying to maintain oil fields without appropriate technical resources)...
Good Answers: 114
#104
In reply to #103
12/17/2009 12:09 AM
Hey this conversation lines up with BBT
In reply to #103
12/17/2009 1:29 AM
"China is a good example of what can go wrong with poorly-conceived population control methods- aging population with insufficient workforce to pay for all the social benefits promised to the retirees"
I will admit I do not know much about China's social structure or state promised benefits. But I was under the impression that the Chinese do not have a guaranteed retirement benefits program. I can't recall where I read it, but it was a statement along the lines of "Chinese citizens save a large portion of their income due to the fact that they are responsible for taking care of themselves once they retire". After writing that statement I think it was in an article on www.financialsense.com a few months ago. It struck me as odd because I had always assumed since China was a communist country, they government would require the entire population to support those in need (non-working citizens). If I recall correctly, the article was discussing why the Chinese government may have a difficult time getting their citizens to help them spend themselves out of the recession.
Something else I recall about China...of course this is a single data point so I don't know how it applies to the general population and it's also quite dated. I used to work with a woman who was married to a man from China. His family still lived in China and he had to send home $300/month as a way of helping provide for his parents. She said it was the custom for the male children to do that once they left home as a way of providing for their parents.
Not exactly a bad custom. Might give the parents some incentive to treat the children right (especially the males) and make sure they are educated and have a good career lined up ahead of them.
J B
Good Answers: 213
#107
In reply to #105
12/17/2009 10:42 AM
JB-
You raise some good points, but independent of whether it is the State or the Family that has responsibility for supporting the ancient ones, one still needs more than one worker per generation to provide for two retirees...I would prefer the Chinese system (assuming one could insure adherence to the moral obligation of the offspring to the anticedents), because, as you point out, parents are more prone to invest in the future of their children. In the US system (and others), "forcing" support through taxation (social security IS a tax- were one to invest properly the same amount of money collected by the government, one would have significantly more resources available when one retired) results in the abandonment of familial obligations as a result of the govenrment "promise" of retirement benefits.
But, whether you encourage keeping it all in the family, or mandate it by law, you still need an adequate population of working age to generate the resources to support the aged. This problem is being faced by more and more societies (Japan and Europe as well). especially on the upper end of the wealth scale. I believe that a major issue stems from the fact that a poor man sees his children as assets that will add to the family resources from an early age (assuming the do-gooders do not interfer with their anti child labor laws), while the well-to-do perceive the offspring as an extended liability (requiring very expensive support through the mid-20's). This is, of course, a generalization, and reality consists of all sorts of gray levels in between the two extremes. But this theory does tend to allow for the fact that less economically-advanced societies generally have higher birth rates and thus a younger population than those that appear to have more resources for properly raising children...
In reply to #107
12/17/2009 10:38 PM
Yes, I agree with you regarding one needs more than one worker per generation to provide for two retirees, especially for a sustainable economic situation. In China's case since their standard of living is increasing, I would imagine that a son who is in an advancing career should quite easily provide for both parent. But after a generation or two, that would start to break down (much as SS has in the US). My understanding of China's one child policy is that it's not rigidly enforce or that there are ways to get around it...for instance if you live in a rural area and need children (read 'boys') to help with the farm, etc. you are allowed more than one child.
Laurence Kotlikoff has an excellent book titled 'The Coming Generational Storm: What You Need to Know About America's Economic Future" where he discusses the relative birth rates of countries around the world as well as their respective life expectancies. He breaks countries down into 4 categories (those with high life expectancy and high birth rates, high life expectancy and low birth rates, low life expectancy and high birth rates, low life expectancy and low birth rates). For instance Russia has a low birth rate and low life expectancy, where as many third world countries have high birth rates but low life expectancy and many highly developed countries (Japan, European countries) have high life expectancy but low birth rates. The US still has a birth rate high enough to grow the population and life expectancy that's pretty high so it rates as a high/high country). China, at least when the book was written (2004) was in the low/low category as it's life expectancy was still rather low and due to it's one child law has a low birth rate, too. Eventually he gets around to discussing a decent replacement for Social Security. I doubt it will ever be adopted as the group in Washington don't have enough brains to put together legislation as detailed as what Kotlikoff presents. His plan is intended to be sustainable (i.e. not relying on the work force to cover retirees benefits).
J B
Anonymous Poster (6); bwire (28); cingold (1); cwarner7_11 (15); Garthh (19); HUX (1); JBTardis (10); Jerry New Hampshire (3); johnfotl (4); kevinm (3); marcot (1); nukesub629 (4); s.udhayamarthandan (7); sceptic (4); Smeaton (1); spacecannon (3)
Previous in Forum: Submarine Engineering   Next in Forum: Total Quality Management
