Previous in Forum: HART Communication Software   Next in Forum: Level Transmitters and Closed Tanks
4-20mA
12/08/2009 10:52 PM
Hello,
What will happen if I use 1 pair instrumentation cable to supply 2 transmitters (4-20mA)??
Re: 4-20mA
12/09/2009 3:52 AM
Nothing useful will come out of the cable at the receiving end.
Re: 4-20mA
12/09/2009 4:24 AM
what would be the point in that ??? how would you connect the transmitters in parallel or in series ? weird question !!
Do you not mean a valve positioner ??
United States - Member - US Citizen - Born & Raised Engineering Fields - Control Engineering - HVAC/R Simplified Using PLC Controls Engineering Fields - Instrumentation Engineering - HVAC/R Simplified Using PLC Controls Engineering Fields - Energy Engineering - HVAC/R Simplified Using PLC Controls
Re: 4-20mA
12/12/2009 10:52 PM
Is the cable providing power to the transmitter or is the cable returning a 4-20mA signal from two sources?
1. If power, nothing. This will be fine to supply the transmitters with power from the same source if 4-wire transmitters. It should not be used with multiple two wire current loops.
2. Never could you share the signal from two transmitters on one pair of wires.
"Memorize the calculations, you look like a fool searching your notes while teaching class"
jcchiefeng (1); porky2009 (1); PWSlack (1)
