Previous in Forum: Aluminium Alloys   Next in Forum: What's the Best Coating for Carbon Steel?
PROBLEMS ASSOCIATED WITH WELDING OF DSS OVERLAY CLADDING ON CS
12/09/2009 2:40 AM
What are problems i need to avoid during manaufacturing of CS + DSS cladding?
If i have to carry out PWHT of CS will this cause effect on DSS interms of strength and corrosion resistance?
Re: PROBLEMS ASSOCIATED WITH WELDING OF DSS OVERLAY CLADDING ON CS
12/09/2009 6:41 AM
the problem that you can have is a non correct balance of ferrite-austenite in the overlay, and also if you make a PWHT after welding there will be the possibility of precipitation of Intermetallic Phases that reduce the corrosion resistance of the overlay.
http://www.outokumpu.com/35058.epibrw
http://files.aws.org/wj/supplement/wj0506-91.pdf
http://www.outokumpu.com/applications/upload/pubs_5293738.pdf
http://www.corrosionist.com/Materials_Stainless_Steel_Welding.htm
S
rust prevention & control
