Previous in Forum: Suppliers of Kindle-Like Displays   Next in Forum: RS 232 Converter and ADSL Modem
Pro-Face Panels: Uploads and Downloads
12/09/2009 9:29 AM
I have new proface panel type GP37W2-BG41-24V and I want to upload the data from existing one and down load it to new one. can any one give the cable connection and software type for this purposes. thanks.
Zainal Abidin
Re: Pro-Face Panels: Uploads and Downloads
12/10/2009 3:55 AM
Proface can help you with your request.
Alternatively, if you are replacing the panel because the screen has been smashed , just swap the innards over, taking care not to disconnect any batteries !!
12/10/2009 9:52 AM
Hi bangzainal,
It's been quite sometime since I used a Proface HMI. I think you'll find it very difficult to manufacture you're own cable to download a project from your PC to the HMI. As I think there's some inline converter between the 9 pin 'D' Type connector (RS232C COM port on your PC) and, the circular 8 pin connector to the HMI. You can purchase the cable from Proface (they're not that expensive approx. £50), I think the Part # is GPW-CB02.
As for the software, the old software I used was called GP-PRO/PBIII (again from Proface). I'm not sure whether they're new software (GP-Pro EX), is compatable with your HMI. Can't see why not, as Proface are a good company and tend to keep things backward compatable. All manuals come as .pdf files on the CD. Downloading the project into the new HMI should be an easy job, as long as you've got the cable and software.
12/11/2009 9:13 AM
Pls its better u contact Proface for good solution.
Patrick Whowha
Patrick Whowha
04/23/2019 3:43 AM
You can find the relevant information about proface GP37W2-BG41-24V touchscreen
VICAPS HMI Parts Center: Touchscreen-Keypad-LCD Displya-Protective Film
Register to Reply 4 comments
Anonymous Poster (2); Patrick Whowha (1); VICAPS HMI Parts (1)
