Previous in Forum: Butterfly Valves   Next in Forum: SPM Analyser
Displacer-Type Level Transmitter
12/10/2009 2:36 AM
can anyone tell me how to find the weight of the displacer + hanger in air = ?,
the details are as follows
length of the displacer (L) = 35.6 cms
diameter of the displacer (D) = 4.24 cms
volume of the displacer = 22x4.24x4.24x35.6/7x4 = 502cubic cms
displacer extension length = 319.8 cms
specific gravity of oil = 0.911
weight of the displacer + Hanger in air (W) = ? grams
( how do i get this answer pls help me to find the equation and the formula used to get in grams)
cajetan
Engineering Fields - Control Engineering - New Member United States - Member - New Member Popular Science - Weaponology - New Member
Re: Displacer-Type Level Transmitter
12/11/2009 9:11 AM
Did you try to contact the manufacturer? And why do you need to know the weight? The easiest way is to disassemble and weigh each component then add the weights for a total. Knowing the sizes is only going help if the material the component is made of, is it hollow or solid?
The basic equation for weight is;
Weight = (mass * gravitational acceleration) / (gravitational constant)
I am assuming this is in a level switch and would try the manufacturer first.
Good Luck
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
