Previous in Forum: Custom Pump Manufacturer Wanted   Next in Forum: Suppliers of Neoprene Sheets
8 comments
Engineering Fields - Manufacturing Engineering - Look for solutions before the problem occurs
Heat-Activated Epoxy
12/10/2009 11:33 AM
I am looking for an epoxy that uses heat (<135 C) as the catalyst. Once it is activated then it will withstand heat up to 175C. It needs to have a viscosity (Shear Viscosity) from 3 to 3.5. It has to be non-conductive and non corrosive to brass, aluminum, Teflon, fiberglass and gold. It will be used for potting material in a connector configuration.
Any Information will be welcomed
Doug
Pathfinder Tags: Potting material
Re: Heat-Activated Epoxy
12/10/2009 3:05 PM
3M, Emerson Cuming, Ablestik, etc. all offer high temp materials. The "pot life" of these may satisfy your desire that they not cure at room temperature, or they may have a product that is premixed that will work.
You need to contact them directly, and tell them exactly what you need.
Good Luck
12/10/2009 4:04 PM
Also try "DYMAX" corporation in the USA. They manufacture UV cure potting materials that also cure by prolonged heat exposure.
They sell the products as "encapsulant" or "conformal coating" into the electronics industry and I'm sure they would have a formulation that is in that range.
12/10/2009 11:56 PM
Try Belzona, the best I have come across
sisira
12/11/2009 9:15 AM
All catalyst cured single component epoxies cure at a higher temperature. Most need about 170C and can stand a higher temperature after curing. We use such a product in India from Anabond.
bioramani
Good Answers: 42
12/11/2009 11:30 AM
I would recommend the product ROTARY SCREEN PHOTO EMULSION directly or in combination with sensitizers which is used for U.V based hardening followed by heat hardening up to 180 degree centigrades. The coating formed qualifies all your said conditions. Just log on to the web site of STORK SCREENS or ZIMMER SCREENS. You will get country wise contacts , product literature and further details. This product will find additional application to your need I suppose. The adhesive is actually meant for NICKEL screen coating meant for printing use. Regards and feel free to ask for more clarifications
Nature is so graceful and naked. Human possession is ridiculous.
12/11/2009 4:28 PM
Hello The ProblemSolver,
You have a problem. All those different plastics, metals and other materials have different coefficient of dilatation and contraction, and that will be a problem with one and unique epoxy adhesive/potting composition. Talk to Dow Chemicals, they are manufacturing epoxies and have solution for many, and I hope for you too. Best wishes for your communication with them or another epoxy producers, Gil.
Just an opinion.
12/14/2009 9:24 PM
Thanks for all replies. I am investigating these sources and will continue until I have found the product needed. Please continue with responses. I will post results as I find them. Thanks again. Doug
12/16/2009 7:16 AM
After looking at many options with the epoxy, I have convinced the lead engineer to use a different approach to the problem. The contacts with wires shall be pressed into a polymer such as Delrin or Acetal Copolymer and then secure in the extrusion with internal set screws, thus removing the need for the epoxy. Also the temps that I had been given were in F not C. A typo from the tech writer. Thanks for the replies. I have learned a lot from them and undoubtedly will use the info at a later point.
Thanks again
Doug
Register to Reply 8 comments
bioramani (1); Gil Becker (1); Just an Engineer (1); lyn (1); s.udhayamarthandan (1); Sisira (1); TheProblemSolver (2)
You might be interested in: Activated Carbon, Epoxy Adhesives, Masking Tapes
