Previous in Forum: Heat-Activated Epoxy   Next in Forum: Measuring Raised Face Flanged Pipe Spools
12 comments
Suppliers of Neoprene Sheets
12/10/2009 3:44 PM
Help! I am in need of a manufacturer of neoprene. I have found many companies on the web who make neoprene in rolls, however our process requires sheet stock in specific sizes. We also have a special formula that enhances the neoprene. So, I need a company that can actually mix the compound and process into sheet stock.
Re: Suppliers of Neoprene Sheets
12/10/2009 4:44 PM
Even if no one specifically markets cut-to-size sheet stock, you might still approach such a company and see what they can do. Of course, roll stock can be turned into flat pieces with a knife, but if you need large numbers....
12/11/2009 9:29 AM
Tornado...thank you for replying. We have tried approaching companies about manufacturing in sheet stock, however, we have yet to find one that will work with us since we don't use enough inventory for them to justify!
But thank you for replying!
Good Answers: 18
12/11/2009 10:13 AM
Slitters (or flying cutters) aren't necessarily very expensive, and your volume may make it economically feasible to purchase and cut your own flat stock.
12/11/2009 9:31 AM
Thank you...Thank you....we were never quite sure what type company we needed! I can tell you that I have never researched a custom compound company, so maybe we can find someone to help us!
Thanks again!
12/11/2009 6:11 AM
If you give full specifications, may be I can offer the sheets you need.(from India)
12/11/2009 9:33 AM
Thank you for replying, hoswever, we have tried to source our cushion in India and other places, however, with the amount of cushion needed and shipping costs, we have never been able to afford having it manufactured out of the states. But...thank you for replying!
12/13/2009 11:09 PM
Hi Pad lady
Shipping cost may be high, but basic cost will be much less than manufacturers from states.
Besides, low volume problem will not be there while purchasing from India
12/11/2009 10:14 AM
I suggest Kirk Hill Rubber Company in Brea, CA. They are owned by a conglomerate, the web site is www.esterline.com They are custom rubber processors.
Good Answers: 58
12/11/2009 3:20 PM
For similar problems, we contact Greene Rubber Company in Woburn, MA. They have sources that can usually supply exactly what we need.
11/24/2013 6:55 AM
Oil & Heat Resistant Premium Gr. Neoprene Rubber Sheets
Source: http://rubbersheetindia.co.in/neoprene-rubber-sheet/
Anuj K. Jain
04/15/2014 1:04 AM
Yes, neoprene rubber sheets are well known for its chemical resistance. It is also known for its chemical inertness. It is used for wide range of applications. Products manufactured out of Neoprene rubber has very low oxidation rate too.
Register to Reply 12 comments
Bill (1); davidjohn (1); goGreen (1); gsuhas (2); lyn (1); Robert Trout (1); The Pad Lady (3); Tornado (1); welderman (1)
