Any problem with using galvanized pipe as a heat circulator for my fireplace? I would place the pipe vertically in front of the fireplace leaning against the mantle, not in the fire. I'm just trying to capture as much heat as possible until my HVAC is repaired, hopefully this evening. The pipe would heat, causing convection, pull cool air from the floor and exhaust warm air about 65" above the floor.
Thanks,
Don
