Previous in Forum: Software for Designing Mechanical Components   Next in Forum: Bouncing Emails
Language Conflicts in Microsoft Office
12/12/2009 2:28 AM
Hi All
in my work computer I've my operating system (windows xp,and Office Xp in English)
when I made a backup copy of my contacts in work computer's msoutlook ,to avoid unexpected failure or any other risks, then I tried to download this copy to my home computer whose programme language is Turkish there were no information visible on the outlook though at leftbottom of the outlook windows the real number of contacts which were in the backup copy is written exactly
Re: Language Conflicts in Microsoft Office
12/12/2009 10:54 PM
You may not have a language problem. I suspect you have an Outlook problem. Simply put, Outlook's export functions don't always work.
The only way I've been able to transfer Outlook files is to export them to an Excel file, email the file to another computer, and then import it into that computer's Outlook. You have to be careful, though--don't let Outlook export everything (the default setting), because it overloads Excel with a lot of garbage, and it won't import it properly. Use the Map Custom Fields function to decide exactly how much information you want to export. I suppose this would also work by exporting the file to a thumb drive or a 3.5 in. floppy, but I haven't tried that.
Life is like a sewer. What you get out of it depends on what you put into it.--Tom Lehrer
12/13/2009 5:40 AM
I think that you have to install both languages on both the PCs as fonts of both are different.
You will need the System-CD supplied with the systems.
go to <View> -> <Encoding> -> <More> and from [Drop-down] list select your language
UTF-8
Register to Reply 2 comments
