Previous in Forum: Automatic Generator Changovers   Next in Forum: Delta Starter Diagram
Synchronous Generators
12/12/2009 7:04 AM
what is the working principle of the syncronous generator?which supplies are given to the stator and rotor?
Re: Synchronous Generators
12/12/2009 8:01 AM
There is a rotating field and that induces an emf in the stationary coil
or there is a stationary field that creates an emf in a rotating coil.
In brief, there is a constant relative motion between the maxnetic flux and a bunch of coils. this automatically creates the emf.
rest: read text book and then write your report. Submission on Monday?
12/12/2009 11:56 PM
There is an exciter power supply that delivers around 480VDC.
India - Member - New Member
Good Answers: 164
12/13/2009 3:52 AM
My apologies if i sounded condescending .. it appears that you are not in the homework zone.
The generator will have to be run precisely at 3000/1500/750/375 .. rpm if the stator is wound for 2/4/6/8 .. poles in a 50Hz country... and 3600/1800/900/450 .. if in USA and others who use 60Hz.
Hope it helps.
Good Answers: 164
12/12/2009 10:58 PM
This is a Generator ... so you input mechanical power and get electrical power..right ?
It is 'synchronous' .. so the power generated is at 50 Hz or 60 Hz depending on where you live.
A DC supply is usually given to the rotor to create a magnetic field. The rotor, as the name implies, is rotated by mechanical means (water, wind, a motor .. whatever) at a speed which generates a 50 / 60 Hz voltage in the Stator which carries stationary windings.
Sufficient for Monday ?
